iBubble dock icon from Adium (or alternatives)
I'm looking for the iBubble bubbles from Adium. In PNG for use with my (jailbroken) iPod Touch. The creator is named Iiro Jäppinen, but his site is down.
Also interested in alternative chat bubbles or other brilliant ideas for a chat application (more spesifically Apollo for the iPhone/iPod Touch)
Thanks!
#483715
Ahh yes. There it is in all it's loveliness. Thank you. I didn't know it could be downloaded outside of Adium as well.
Since it isn't a png but an icon, I renamed it to something.png and then opened it in an image editor and extracted the png I wanted from the stack. Hope I have done it correctly because my image has a tiny icon inside the folder on my hard drive, whereas the iPod png's have big icons. Maybe there are different png formats or something? Nevertheless the icon dimentions are the same and it works inside my iPod now.
Thank you again!
#483753
Or to be more precise, here it is in place:
Thanks again!
#483760
AdiumXtras.com is where people with Adium download the themes, et cetera.
Your iPod touch is resizing the image to it's dimensions. The PNG should be 128x128. The iPod touch and iPhone use a non-standard 59 (width) x 60 (height). You will need to resize the document to fit those dimensions, otherwise it will be stretched.
#483768
