1.. 0 Posted July 25, 2010 Report Share Posted July 25, 2010 hi,I installed Aqua-skin on my phpbb 3.07pl1 forum, in the admin log, there are a lot of messages:Imageset misses “en†localisation» Aqua-SoftImageset misses “en†localisation» Aqua-SoftImageset misses “en†localisation» Aqua-SoftImageset misses “en†localisation» Aqua-SoftImageset misses “en†localisation» Aqua-SoftImageset misses “en†localisation» Aqua-SoftImageset misses “en†localisation» Aqua-Soft.........need help, thank you. Link to post
Timan 0 Posted July 26, 2010 Report Share Posted July 26, 2010 Hmm, i'm actually not sure what that would happen. I've not seen that issue popup before. By any chance do you have any modifications for your forums? Link to post
1.. 0 Posted July 27, 2010 Author Report Share Posted July 27, 2010 (edited) Hmm, i'm actually not sure what that would happen. I've not seen that issue popup before. By any chance do you have any modifications for your forums?no, that's a fresh install without any modifications. now, I put the default "en" and "en_us" folder in /styles/as4/imageset/, it seems to work, but I don't know the reason.Would you kindly answer my another question? Edited July 27, 2010 by 1.. Link to post
