Panta 0 Posted March 4, 2009 Author Report Share Posted March 4, 2009 Edit: this should be in the faq. I bet lots of people won't be able to get office icons working. why, instead of simply saying this, don't you, a seasoned XWD user, create a new entry at Post Your Suggestions for Our FAQ (Q&A) Here... Link to post
xcadaverx 0 Posted March 4, 2009 Report Share Posted March 4, 2009 (edited) i'm getting an access violation when i try to open the preferences window. after i click ok, the preferences window opens but the OK button is inactive even after a setting is changed. and the list on the left of the window has no text, just icons. not that big of a deal since everything is already customized how i want, but if i want to change something later or switch skins, can't do it. this happened after i installed the XTasks v0.1 docklet. i thought that might be the culprit. so i uninstalled it and the problem persists. =/ Edited March 4, 2009 by xcadaverx Link to post
AndrewYY 0 Posted March 4, 2009 Report Share Posted March 4, 2009 (edited) i'm getting an access violation when i try to open the preferences window. after i click ok, the preferences window opens but the OK button is inactive even after a setting is changed. and the list on the left of the window has no text, just icons.not that big of a deal since everything is already customized how i want, but if i want to change something later or switch skins, can't do it.this happened after i installed the XTasks v0.1 docklet. i thought that might be the culprit. so i uninstalled it and the problem persists.=/try renaming the 3 xml files and see if any of them are messing with the dock? If not, backing up the xml files, re-installing XWD, and replacing the xml files should fix it.edit: woops, fixed. Edited October 12, 2009 by AndrewYY Link to post
xcadaverx 0 Posted March 5, 2009 Report Share Posted March 5, 2009 fixed.i copied over the 3 files and my skins, effects, etc. into a new install Link to post
newgriptape 0 Posted March 5, 2009 Report Share Posted March 5, 2009 Hello, Could someone please tell me how to disable UAC for X Windows Dock? This question is of course in regards with the pesky (infamous) error message I receive upon startup. -I know that trying a reinstall (in places other than Program Files) usually fixes this problem, but after many reinstalls, I am getting no where, I just want this to end so that this program runs smoothly. Thanks! Link to post
Panta 0 Posted March 6, 2009 Author Report Share Posted March 6, 2009 (edited) @newgriptape: I was talking to Andrew; now, please, stop double-posting! Regarding UAC, you don't disable it for a single application; this is done for the system as a whole. Edited March 6, 2009 by Panta Link to post
newgriptape 0 Posted March 6, 2009 Report Share Posted March 6, 2009 @newgriptape: I was talking to Andrew; now, please, stop double-posting! Regarding UAC, you don't disable it for a single application; this is done for the system as a whole. Okay, I have tried disabling UAC, and I have tried a clean reinstall many times. It still shows this error upon startup. -Btw, I'm sorry for the double post. I am not deliberately doing that... Link to post
Panta 0 Posted March 6, 2009 Author Report Share Posted March 6, 2009 In my experience every time a clean install is done this message appears at the first run - I suspect it's due to the absence of the *.xml files (or, at least, DockItems.xml) - but if you click OK, then XWD will run normally (I'm on Vista 32-bit and this scenario always occurs, but only this one, as I have UAC disabled). Link to post
cns081384 0 Posted March 6, 2009 Report Share Posted March 6, 2009 why on startup my dock having cut and moved to left side having icon cut and some are lost..im using objectbar.they put on left side..why in other dock is normal..stil in center. and also having error code like everyone does..mybe i have to rest shorty using this dock..til not stable. Link to post
yorkey 0 Posted March 6, 2009 Report Share Posted March 6, 2009 why on startup my dock having cut and moved to left side having icon cut and some are lost..im using objectbar.they put on left side..why in other dock is normal..stil in center. and also having error code like everyone does..mybe i have to rest shorty using this dock..til not stable.Can you give us a screenshot perhaps, and what OS version are you on? Link to post
cns081384 0 Posted March 6, 2009 Report Share Posted March 6, 2009 here my screenshot.. actually shot on startup..im usingn 5.3 because im having error pop up in 5.4 or 5.6 can solve this????? Link to post
my99 0 Posted March 6, 2009 Report Share Posted March 6, 2009 (edited) Dont know if this has been mentioned before but there seems to be a conflict with avedesk and XWD, every time avedesk is open the magnification doesn't work close avedesk and it works fine Anyone else have theses issues? I'm running vista. By Panta: moved. Edited March 7, 2009 by Panta Link to post
edgordil 0 Posted March 9, 2009 Report Share Posted March 9, 2009 Hi,I got a little problem with minimizing to the dock. Normally if I got several windows of the same program running at the same time (like safari) and I want minimize one of them, the other ones will too! What can I do?Thanks for ur help! Link to post
kees1869 0 Posted March 9, 2009 Report Share Posted March 9, 2009 Dont know if this has been mentioned before but there seems to be a conflict with avedesk and XWD, every time avedesk is open the magnification doesn't work close avedesk and it works fine Anyone else have theses issues? I'm running vista. By Panta: moved. It's a known bug, AveDesk 1.3 doesn't have the problem. Link to post
my99 0 Posted March 11, 2009 Report Share Posted March 11, 2009 It's a known bug, AveDesk 1.3 doesn't have the problem. Thanks for the reply Link to post
Borix 0 Posted March 11, 2009 Report Share Posted March 11, 2009 Sorry, perhaps a noob question, but how do you change the trash icon (empty and full)? Link to post
BurntAsafoetida 0 Posted March 11, 2009 Report Share Posted March 11, 2009 You can't. It's already described on skin file. Link to post
xcadaverx 0 Posted March 12, 2009 Report Share Posted March 12, 2009 is there a way to change the highlighted item in the context menu from gray to blue? Link to post
AndrewYY 0 Posted March 13, 2009 Report Share Posted March 13, 2009 is there a way to change the highlighted item in the context menu from gray to blue? nope. Sounds like a feature request Link to post
kees1869 0 Posted March 13, 2009 Report Share Posted March 13, 2009 You can't. It's already described on skin file.You can edit the skin file though, put in the paths to the new trash icons and drop the edited config file on skinmaker.exe to generate the updated skin. Link to post
parry 0 Posted March 14, 2009 Report Share Posted March 14, 2009 Is there any way to have the dock at the top of the screen? I've only ever seen it at the bottom in screenshots. Link to post
AndrewYY 0 Posted March 14, 2009 Report Share Posted March 14, 2009 Is there any way to have the dock at the top of the screen? I've only ever seen it at the bottom in screenshots.Nope. This has been a frequently suggested feature in the past. Link to post
parry 0 Posted March 14, 2009 Report Share Posted March 14, 2009 I hope it's implemented in future. It's the only thing stopping me from using this. Link to post
danhoven 0 Posted March 21, 2009 Report Share Posted March 21, 2009 its also happen to me posted #186 post by mewky...do u knw how to fix this on startup.its same like mine..if u wna know what im talking about..just try objectbar and xwindows dock on startup.. while from other dock its start normal..i have new version 5.6+ nw.tnx Link to post
scissorhands7 0 Posted March 21, 2009 Report Share Posted March 21, 2009 (edited) I've come up with a great fix for a bug in the latest version. I did have my settings like this:Cache items in Ram for faster viewing (checked)image width = 200 pixelsImage height = 200 pixelsNumber of visible items = 5Space between items = 11Item to Reflection Ratio = 1/3Things were working well except like every 1/10 images wouldn't render and it would preview as just a black image. The name would show up and if I clicked it my image would popup but no preview. Now I use xwindows dock primarily for the gallery feature so I was a little bummed but this time I can cache the items so they go faster. I mainly use this to change my wallpapers in an attractive manner I'm a big wallpaper guy. So anyways I fooled around and fixed the bug by myself. I set the settings to these:Here are my gallery settings:Cache items in RAM for faster viewing (checked)Image width = 180 pixelsImage Height = 180 pixelsNumber of visible items = 11Space between items = 11Item to Reflection ratio = 1/3But this fixed the random black box (I think because I set the visible items higher and this in turn gave the gallery time to load the picture before it became visible to me. So there was no problem in rendering? that's just a guess. Anyways there was still a problem that remained. That was I couldn't then see my last two pictures in my gallery because although they were loading correctly they were out of view (due to the 10 items at once deal)UPDATE:You also have to create 3 bmp images and place them in the folder that you have a gallery. I'm not sure how to make them go to the end of the gallery because I cannot figure out Boobah's sorting system. If Boobah could tell me how he sorts the pictures then this would fix not being able to see the last 3 pictures.UPDATE 2: After messing around some more I've found that they are generally sorted by date modified. So in some instances just making 3 new bmp files works but in others the bmp files end up in the middle of the gallery? Still curious about this and I'll get back to you if I figure it out. Edited March 21, 2009 by scissorhands7 Link to post
