SaRRaZin 0 Posted January 31, 2009 Report Share Posted January 31, 2009 @SaRRaZin: but after showing this message the dock runs normally? I'm asking because I get this error message every time I do a clean install, only the first time I run XWD after that kind of installation, but then the dock shows up and everything runs fine afterwards...Yes after this message XWD run normaly exept the magnification dont work ! Link to post
Panta 0 Posted January 31, 2009 Author Report Share Posted January 31, 2009 Yes after this message XWD run normaly exept the magnification dont work !You have to configure it at the preferences window; right-click at the dock and select 'Preferences'. Link to post
Calvin360 0 Posted January 31, 2009 Report Share Posted January 31, 2009 could anyone give me the link to the download Link to post
Panta 0 Posted January 31, 2009 Author Report Share Posted January 31, 2009 @all: download link is working normally! Gentlemen, cleanup your caches - both browser and also any download manager you may be using... I pasted over all three xml files and it worked for me o_OQuite inaccurate info Andrew; docklets are incompatible! And settings have also been extended... Link to post
AndrewYY 0 Posted January 31, 2009 Report Share Posted January 31, 2009 Quite inaccurate info Andrew; docklets are incompatible! And settings have also been extended...Of course the docklets aren't compatible, but the new docklets so far will work with the old xml files, and if they don't, the files will be ignored. No errors are coming up for me. Same with the settings. Link to post
SaRRaZin 0 Posted January 31, 2009 Report Share Posted January 31, 2009 You have to configure it at the preferences window; right-click at the dock and select 'Preferences'.I played with "icon size when hovered" and "magnification time span" but no result thank's for help anyway good night Link to post
Panta 0 Posted January 31, 2009 Author Report Share Posted January 31, 2009 Of course the docklets aren't compatible, but the new docklets so far will work with the old xml files, and if they don't, the files will be ignored. No errors are coming up for me. Same with the settings.Except one can get 'invisible' icons for docklets unless everything is present and at the same places... that's why I said inacurate, and not wrong... but... we're not going to turn this thread into another 'chat' one, are we? Please, hold your horses! Only support here. Link to post
Calvin360 0 Posted January 31, 2009 Report Share Posted January 31, 2009 http://nemecsx.narod.ru/Theme/XWindowsDockInstaller.zipi tried this download link but i still cant download itive tried fire fox, safrai and i.e Link to post
Panta 0 Posted January 31, 2009 Author Report Share Posted January 31, 2009 I played with "icon size when hovered" and "magnification time span" but no result thank's for help anyway good nightHave you checked 'Magnify' check box (the very first one)? Link to post
Panta 0 Posted January 31, 2009 Author Report Share Posted January 31, 2009 http://nemecsx.narod.ru/Theme/XWindowsDockInstaller.zipi tried this download link but i still cant download itive tried fire fox, safrai and i.eNobody is authorized by bobah for supplying an alternate link but, as I said, the link is working! I've checked it myself right now - I use FF...@all: now, let's stop complaining about 'download link not working'! If bobah decides changing from his current server to another one, I'm sure he'll let us all know about it. Link to post
SaRRaZin 0 Posted February 1, 2009 Report Share Posted February 1, 2009 Have you checked 'Magnify' check box (the very first one)?yes ;_p and i have'nt magnification strange !!! Link to post
Calvin360 0 Posted February 1, 2009 Report Share Posted February 1, 2009 on 5.6the minimizing windows, when i choose genie affect it dosent do anything its like i have no option selectedlike the way the windows minimize to the taskbarcan any 1 help me plz? Link to post
estrahon 0 Posted February 1, 2009 Report Share Posted February 1, 2009 everything works fine except the magnification.I also can't move any icons around.By Panta: no need for double-posting! Use edit instead... :slant: Link to post
AndrewYY 0 Posted February 1, 2009 Report Share Posted February 1, 2009 @estrahon: probably shouldn't double post @Calvin360: Have you tried changing the speed? There's a new feature where if it's dragged all the way to the right, windows will minimize instantly. Link to post
BOBAH13 0 Posted February 1, 2009 Report Share Posted February 1, 2009 About codecs, it can not be shown, it doesn't depend on me. But they must be played Link to post
randomus r 0 Posted February 1, 2009 Report Share Posted February 1, 2009 I get no dock labels and no magnification on Vista 32bit I originally copied over the dockitems.xml when updating to 5.6, but I've since reinstalled and it's now a default installation. Labels and magnification are on; Link to post
BOBAH13 0 Posted February 1, 2009 Report Share Posted February 1, 2009 I get no dock labels and no magnification on Vista 32bit I originally copied over the dockitems.xml when updating to 5.6, but I've since reinstalled and it's now a default installation. Labels and magnification are on; It's impossible, because: 1. I installed global hook, using .dll, so if it doesn't work then your windows doesn't give the dock to use global hooks Also magnification and labels depend on this mouse event (I mean global hook from dll). So if windows doesn't want to make it possible, sorry I can't do anything about it. May be you have got some programs, like spyware which close software like my dock using global hooks. Link to post
Panta 0 Posted February 1, 2009 Author Report Share Posted February 1, 2009 It's impossible, because: 1. I installed global hook, using .dll, so if it doesn't work then your windows doesn't give the dock to use global hooks Also magnification and labels depend on this mouse event (I mean global hook from dll). So if windows doesn't want to make it possible, sorry I can't do anything about it. May be you have got some programs, like spyware which close software like my dock using global hooks. Bobah, are you using anything that could prevent a user without administrative rights from running XWD? Global hooks seems a good candidate for that... Link to post
randomus r 0 Posted February 1, 2009 Report Share Posted February 1, 2009 So this means it won't work on Vista? The labels and magnification worked on previous versions... Link to post
Panta 0 Posted February 1, 2009 Author Report Share Posted February 1, 2009 So this means it won't work on Vista? The labels and magnification worked on previous versions...Hold your horses, buddy! Nobody said that; besides, I'm on Vista 32bit and everything's just fine. Let's just wait bobah reply to my question... Link to post
randomus r 0 Posted February 1, 2009 Report Share Posted February 1, 2009 Hold your horses, buddy! Nobody said that; besides, I'm on Vista 32bit and everything's just fine. Let's just wait bobah reply to my question... lol, he did say it was impossible Link to post
Panta 0 Posted February 1, 2009 Author Report Share Posted February 1, 2009 No need for making fun of it... Unlike you, he hasn't English as his native language but, in spite of that, he's trying to communicate with you in English; perhaps you could get better results if you try communicating with him in Russian. Why don't you try doing so? Link to post
randomus r 0 Posted February 1, 2009 Report Share Posted February 1, 2009 Ah. I wasn't aware he wasn't English. My apologies Link to post
Panta 0 Posted February 1, 2009 Author Report Share Posted February 1, 2009 No problem, вы должны попробовать написать используя Cyrillic сценарий для более лучших результатов... Link to post
estrahon 0 Posted February 2, 2009 Report Share Posted February 2, 2009 Why would Windows not allow the use of global hooks if the magnification worked in the last versions that I've used? It worked perfectly with 5.4 but I had to update after the dock started to malfunction. Now things don't work. I have Vista 64-bit installed. Link to post
