skdj 0 Posted May 6, 2009 Report Share Posted May 6, 2009 I believe someone asked this long time ago, and I remember that it´s not possible... Link to post
AndrewYY 0 Posted May 6, 2009 Report Share Posted May 6, 2009 (edited) Someone asks this every week, it seems, and the answer is always no. Use Rocketdock or RK Launcher or something. Edited May 6, 2009 by AndrewYY Link to post
holo13x 0 Posted May 6, 2009 Report Share Posted May 6, 2009 it does suck you cant change the side its o, maybe they will make another update 4 that, i really hope so! Link to post
Mycorrhiza 0 Posted May 10, 2009 Report Share Posted May 10, 2009 Is there a possibility to make the panel smaller? I only have a 13" laptop with limited resolution so I like to have as much of my screen as possible whilst still showing the icons. Thanks for the info Link to post
AndrewYY 0 Posted May 10, 2009 Report Share Posted May 10, 2009 Is there a possibility to make the panel smaller? I only have a 13" laptop with limited resolution so I like to have as much of my screen as possible whilst still showing the icons. Thanks for the info It is possible if you make a custom theme. If you don't know how, pm me with the theme you're using, and I can shrink it down for you Link to post
elbichocba 0 Posted May 11, 2009 Report Share Posted May 11, 2009 Everytime I install the dock, it gives me a problem with internet explorer.. It closes my internet explorer windows, and wont let me open them anymore, I restarted my computer a few times, installed it and uninstalled it a few times too but I kept having the same problem..I've been reading previous posts but never found anyone with the same problemI have w vista 32b home edition.. any suggestions? Link to post
btb42693 0 Posted May 11, 2009 Report Share Posted May 11, 2009 This is a known bug, and there are many other questions just like yours throughout the forum. For now, just like Andrew said, the developer has discontinued creating this program, and the only solution to getting around the Internet Explorer issue is to use another browser (i.e. Safari, Firefox, Opera, Chrome, AT&T's Browser, etc) (I prefer either Safari or Firefox). All the other browsers, as far as I know, work with XWD. Link to post
elbichocba 0 Posted May 12, 2009 Report Share Posted May 12, 2009 mmm ok thanks for the answer.. Link to post
betterkw 0 Posted May 12, 2009 Report Share Posted May 12, 2009 when i reboot my pc it always happened~ what's wrong with it? Link to post
cnterr 0 Posted May 13, 2009 Report Share Posted May 13, 2009 In preference menu there are two options for icon bounce effect, but this setting works with externals docklet only. Is this a my problem or this feature is not implemented directly in this release?Many thanks! Link to post
Memophysic 0 Posted May 15, 2009 Report Share Posted May 15, 2009 Everytime I install the dock, it gives me a problem with internet explorer.. It closes my internet explorer windows, and wont let me open them anymore, I restarted my computer a few times, installed it and uninstalled it a few times too but I kept having the same problem.. I've been reading previous posts but never found anyone with the same problem I have w vista 32b home edition.. any suggestions? I think I've found a solution for you! In fact, that happened to me before. I thought Internet Explorer was the problem but no, it was XWD's fault :rolleyes. Try to go to C:\\Program Files\Internet Explorer\, right-click on iexplorer.exe, click on the compatibilty tab and check "Execute this program as the administrator" and finally click on ok. You sure need the admin rights Now, try opening internet explorer again. It should ask you the right to execute itself with the admin rights, click "Yes" and (I hope so) ta-dam! Internet Explorer opens! Hope this works for you! Link to post
kyosan1988 0 Posted May 16, 2009 Report Share Posted May 16, 2009 (edited) Ok. I can do it Edited May 17, 2009 by kyosan1988 Link to post
kyosan1988 0 Posted May 17, 2009 Report Share Posted May 17, 2009 (edited) when i reboot my pc it always happened~ what's wrong with it? The same date/time : 2009-05-17, 09:16:09, 804mscomputer name : MICROSOF-099CC8user name : HONG HA <admin>registered owner : HONGHA / MICROSOFToperating system : Windows XP Media Center Service Pack 3 build 2600system language : Englishsystem up time : 1 hour 45 minutesprogram up time : 861 millisecondsprocessors : 2x Intel® Pentium® Dual CPU E2160 @ 1.80GHzphysical memory : 1384/2047 MB (free/total)free disk space : (C:) 55.81 GBdisplay mode : 1440x900, 32 bitprocess id : $810allocated memory : 9.95 MBexecutable : XWindowsDock.exeexec. date/time : 2009-05-17 08:55version : 5.6.1.1compiled with : Delphi 7madExcept version : 3.0hcallstack crc : $c326646b, $f03b6b82, $036699a5exception number : 1exception class : EAccessViolationexception message : Access violation at address 00523DEC in module 'XWindowsDock.exe'. Read of address 00000010.main thread ($984):00523dec +050 XWindowsDock.exe Main 3527 +4 TfrmMacXDock.UpdateLayer00529c12 +0d6 XWindowsDock.exe Main 5740 +25 TfrmMacXDock.RecyclerUpdaterTimer0047dbcf +00f XWindowsDock.exe ExtCtrls TTimer.Timer0047dab3 +02b XWindowsDock.exe ExtCtrls TTimer.WndProc0046b778 +014 XWindowsDock.exe Classes StdWndProc7e4196c2 +00a user32.dll DispatchMessageA004b6b8f +083 XWindowsDock.exe Forms 31056 +0 TApplication.ProcessMessage004b6bae +00a XWindowsDock.exe Forms 31056 +0 TApplication.ProcessMessages0052d3d5 +0c5 XWindowsDock.exe Main 7368 +17 TfrmMacXDock.LockEdge0051cad9 +ee9 XWindowsDock.exe Main 1478 +178 TfrmMacXDock.LoadDockSettings0051ee0f +9f7 XWindowsDock.exe Main 1908 +316 TfrmMacXDock.FormCreate004af88d +031 XWindowsDock.exe Forms 31056 +0 TCustomForm.DoCreate004af56d +011 XWindowsDock.exe Forms 31056 +0 TCustomForm.AfterConstruction00403f47 +007 XWindowsDock.exe System @AfterConstruction004af544 +174 XWindowsDock.exe Forms 31056 +0 TCustomForm.Create7c90e470 +010 ntdll.dll KiUserCallbackDispatcher004b6d01 +031 XWindowsDock.exe Forms 31056 +0 TApplication.CreateForm0052d946 +066 XWindowsDock.exe XWindowsDock 36 +9 initializationthread $cdc: <priority:15>7c90df48 +a ntdll.dll NtWaitForMultipleObjectsthread $790:7c90df48 +0a ntdll.dll NtWaitForMultipleObjects7c80958a +00 kernel32.dll WaitForMultipleObjectsEx7e4195f3 +00 user32.dll MsgWaitForMultipleObjectsEx7e4196a3 +1a user32.dll MsgWaitForMultipleObjects0044e189 +0d XWindowsDock.exe madExcept CallThreadProcSafe0044e1f3 +37 XWindowsDock.exe madExcept ThreadExceptFrame>> created by main thread ($984) at:4eca29b1 +00 gdiplus.dllthread $a80 (TGalleryRender): <priority:-15>7c90d218 +0a ntdll.dll NtDelayExecution7c8023eb +4b kernel32.dll SleepEx7c802450 +0a kernel32.dll Sleep00505f04 +20 XWindowsDock.exe ImageGallery 243 +5 TGalleryRender.Execute0044e2a7 +2b XWindowsDock.exe madExcept HookedTThreadExecute0046a220 +34 XWindowsDock.exe Classes ThreadProc00404a1c +28 XWindowsDock.exe System ThreadWrapper0044e189 +0d XWindowsDock.exe madExcept CallThreadProcSafe0044e1f3 +37 XWindowsDock.exe madExcept ThreadExceptFrame>> created by main thread ($984) at:00505de8 +18 XWindowsDock.exe ImageGallery 193 +1 TGalleryRender.Createmodules:00400000 XWindowsDock.exe 5.6.1.1 C:\Program Files\XWindowsDock011f0000 StylerHelper.dll 1.3.1.1 C:\Program Files\Styler02c50000 XWDkernel.dll 5.4.10.1 C:\Program Files\XWindowsDock10000000 DesktopControlPanel.dll 2.0.0.106 C:\Program Files\Stardock\Object Desktop\DeskScapes35020000 adialhk.dll 8.0.0.357 C:\PROGRA~1\KASPER~1\KASPER~1354c0000 kloehk.dll 8.0.0.357 C:\PROGRA~1\KASPER~1\KASPER~14ec50000 gdiplus.dll 5.1.3102.5581 C:\WINDOWS\WinSxS\x86_Microsoft.Windows.GdiPlus_6595b64144ccf1df_1.0.2600.5581_x-ww_dfbc4fc45ad70000 UXTHEME.DLL 6.0.2900.5512 C:\WINDOWS\system3266000000 wblind.dll 6.4.0.0 C:\PROGRA~1\Stardock\OBJECT~1\WINDOW~166600000 wbhelp.dll 4.0.0.1 C:\PROGRA~1\Stardock\OBJECT~1\WINDOW~169b10000 msxml4.dll 4.20.9870.0 c:\WINDOWS\system3271aa0000 WS2HELP.dll 5.1.2600.5512 C:\WINDOWS\system3271ab0000 WS2_32.dll 5.1.2600.5512 C:\WINDOWS\system3271ad0000 wsock32.dll 5.1.2600.5512 C:\WINDOWS\system3273000000 winspool.drv 5.1.2600.5512 C:\WINDOWS\system3273dd0000 MFC42.DLL 6.2.4131.0 C:\WINDOWS\system3274720000 MSCTF.dll 5.1.2600.5512 C:\WINDOWS\system32755c0000 msctfime.ime 5.1.2600.5512 C:\WINDOWS\system3276380000 msimg32.dll 5.1.2600.5512 C:\WINDOWS\system3276390000 IMM32.DLL 5.1.2600.5512 C:\WINDOWS\system32763b0000 comdlg32.dll 6.0.2900.5512 C:\WINDOWS\system3276b40000 winmm.dll 5.1.2600.5512 C:\WINDOWS\system3276fd0000 CLBCATQ.DLL 2001.12.4414.700 C:\WINDOWS\system3277050000 COMRes.dll 2001.12.4414.700 C:\WINDOWS\system3277120000 oleaut32.dll 5.1.2600.5512 C:\WINDOWS\system32773d0000 comctl32.dll 6.0.2900.5512 C:\WINDOWS\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.2600.5512_x-ww_35d4ce83774e0000 ole32.dll 5.1.2600.5512 C:\WINDOWS\system3277920000 SETUPAPI.dll 5.1.2600.5512 C:\WINDOWS\system3277c00000 version.dll 5.1.2600.5512 C:\WINDOWS\system3277c10000 msvcrt.dll 7.0.2600.5512 C:\WINDOWS\system3277dd0000 advapi32.dll 5.1.2600.5755 C:\WINDOWS\system3277e70000 RPCRT4.dll 5.1.2600.5512 C:\WINDOWS\system3277f10000 GDI32.dll 5.1.2600.5698 C:\WINDOWS\system3277f60000 SHLWAPI.dll 6.0.2900.5512 C:\WINDOWS\system3277fe0000 Secur32.dll 5.1.2600.5753 C:\WINDOWS\system327c800000 kernel32.dll 5.1.2600.5781 C:\WINDOWS\system327c900000 ntdll.dll 5.1.2600.5755 C:\WINDOWS\system327c9c0000 shell32.dll 6.0.2900.5622 C:\WINDOWS\system327e410000 user32.dll 5.1.2600.5512 C:\WINDOWS\system32processes:000 Idle004 System normal400 smss.exe normal C:\WINDOWS\system324d0 csrss.exe518 winlogon.exe high C:\WINDOWS\system32574 services.exe normal C:\WINDOWS\system32580 lsass.exe normal C:\WINDOWS\system32624 svchost.exe normal C:\WINDOWS\system326a0 svchost.exe71c svchost.exe normal C:\WINDOWS\System327d8 svchost.exe3bc svchost.exe444 avp.exe normal C:\Program Files\Kaspersky Lab\Kaspersky Internet Security 2009458 mDNSResponder.exe normal C:\Program Files\Bonjour610 iviRegMgr.exe normal C:\Program Files\Common Files\InterVideo\RegMgr6c4 jqs.exe idle C:\Program Files\Java\jre6\bin420 sqlservr.exe318 PsiService_2.exe normal C:\Program Files\Common Files\Protexis\License Service480 sqlbrowser.exe500 sqlwriter.exe normal c:\Program Files\Microsoft SQL Server\90\Shared6e4 svchost.exe748 wdfmgr.exea54 PresentationFontCache.exeda0 alg.exe97c Explorer.EXE normal C:\WINDOWS9f0 ctfmon.exe normal C:\WINDOWS\system32350 RUNDLL32.EXE normal C:\WINDOWS\system32b50 RTHDCPL.EXE normal C:\WINDOWS9e4 avp.exe normal C:\Program Files\Kaspersky Lab\Kaspersky Internet Security 20092d8 jusched.exe normal C:\Program Files\Java\jre6\bin8b4 myBoard.App.exe normal C:\Program Files\Yann ALET\myBoard Alpha 1.088c ObjectBar.exe normal C:\Program Files\Stardock\Object Desktop\ObjectBar3e4 Styler.exe normal C:\Program Files\Styler810 XWindowsDock.exe normal C:\Program Files\XWindowsDockhardware:+ Computer - ACPI Multiprocessor PC+ Disk drives - Generic USB CF Reader USB Device - Generic USB MS Reader USB Device - Generic USB SD Reader USB Device - Generic USB xD/SM Reader USB Device - SAMSUNG HD252KJ - WDC WD800BB-22JHC0+ Display adapters - NVIDIA GeForce 8400 GS (driver 6.14.11.8206)+ DVD/CD-ROM drives - ATAPI DVD C DH48C2S+ IDE ATA/ATAPI controllers - Intel® 82801G (ICH7 Family) Ultra ATA Storage Controllers - 27DF (driver 8.2.0.1011) - Intel® 82801GB/GR/GH (ICH7 Family) Serial ATA Storage Controller - 27C0 (driver 8.2.0.1011) - Primary IDE Channel - Primary IDE Channel - Secondary IDE Channel - Secondary IDE Channel+ Keyboards - Standard 101/102-Key or Microsoft Natural PS/2 Keyboard+ Mice and other pointing devices - Microsoft PS/2 Mouse+ Monitors - Plug and Play Monitor+ Network adapters - Realtek RTL8139/810x Family Fast Ethernet NIC (driver 5.686.103.2008)+ Processors - Intel® Pentium® Dual CPU E2160 @ 1.80GHz - Intel® Pentium® Dual CPU E2160 @ 1.80GHz+ Sound, video and game controllers - Audio Codecs - Legacy Audio Drivers - Legacy Video Capture Devices - Media Control Devices - Realtek High Definition Audio (driver 5.10.0.5591) - Video Codecs+ System devices - ACPI Fixed Feature Button - ACPI Power Button - Direct memory access controller - High precision event timer - Intel® 82801 PCI Bridge - 244E - Intel® 82801G (ICH7 Family) PCI Express Root Port - 27D0 (driver 8.3.0.1011) - Intel® 82801G (ICH7 Family) SMBus Controller - 27DA (driver 8.3.0.1011) - Intel® 82801GB/GR (ICH7 Family) LPC Interface Controller - 27B8 (driver 8.3.0.1011) - Intel® 82802 Firmware Hub Device - Intel® 945G/GZ/GC/P/PL PCI Express Root Port - 2771 (driver 8.3.0.1011) - Intel® 945G/GZ/GC/P/PL Processor to I/O Controller - 2770 (driver 8.3.0.1011) - ISAPNP Read Data Port - Logical Disk Manager - Microcode Update Device - Microsoft ACPI-Compliant System - Microsoft System Management BIOS Driver - Microsoft UAA Bus Driver for High Definition Audio - Motherboard resources - Motherboard resources - Motherboard resources - Motherboard resources - Motherboard resources - Numeric data processor - PCI bus - Plug and Play Software Device Enumerator - Programmable interrupt controller - System board - System board - System CMOS/real time clock - System speaker - System timer - Terminal Server Device Redirector - Terminal Server Keyboard Driver - Terminal Server Mouse Driver - Volume Manager+ Universal Serial Bus controllers - Intel® 82801G (ICH7 Family) USB Universal Host Controller - 27C8 (driver 8.2.0.1008) - Intel® 82801G (ICH7 Family) USB Universal Host Controller - 27C9 (driver 8.2.0.1008) - Intel® 82801G (ICH7 Family) USB Universal Host Controller - 27CA (driver 8.2.0.1008) - Intel® 82801G (ICH7 Family) USB Universal Host Controller - 27CB (driver 8.2.0.1008) - Intel® 82801G (ICH7 Family) USB2 Enhanced Host Controller - 27CC (driver 8.2.0.1008) - USB Mass Storage Device - USB Root Hub - USB Root Hub - USB Root Hub - USB Root Hub - USB Root Hubcpu registers:eax = 00000000ebx = 00c631c4ecx = 0012f9acedx = 0000008besi = 00c631c4edi = 00000000eip = 00523decesp = 0012f99cebp = 0012f9ecstack dump:0012f99c 10 35 c6 00 00 00 00 00 - 20 35 c6 00 02 00 00 00 .5.......5......0012f9ac c9 00 00 00 8b 00 00 00 - 01 00 00 00 17 9c 52 00 ..............R.0012f9bc fc f9 12 00 48 43 40 00 - ec f9 12 00 98 fa 12 00 [email protected]0012f9cc c0 db 47 00 68 51 c6 00 - 00 00 00 00 14 00 00 00 ..G.hQ..........0012f9dc 94 fa 47 28 00 00 00 00 - b1 00 00 00 00 00 00 00 ..G(............0012f9ec 18 fa 12 00 d2 db 47 00 - 20 fa 12 00 b8 da 47 00 ......G.......G.0012f9fc b4 fa 12 00 68 41 40 00 - 18 fa 12 00 98 fa 12 00 [email protected]0012fa0c 53 0f 41 02 00 00 00 00 - 68 51 c6 00 30 fa 12 00 S.A.....hQ..0...0012fa1c 7a b7 46 00 13 01 00 00 - 01 00 00 00 00 00 00 00 z.F.............0012fa2c 00 00 00 00 5c fa 12 00 - 34 87 41 7e 24 02 0d 00 ....\...4.A~$...0012fa3c 13 01 00 00 01 00 00 00 - 00 00 00 00 53 0f 41 02 ............S.A.0012fa4c cd ab ba dc 00 00 00 00 - 98 fa 12 00 53 0f 41 02 ............S.A.0012fa5c c4 fa 12 00 16 88 41 7e - 53 0f 41 02 24 02 0d 00 ......A~S.A.$...0012fa6c 13 01 00 00 01 00 00 00 - 00 00 00 00 5c fb 12 00 ............\...0012fa7c 54 fb 12 00 e0 9f 85 00 - 14 00 00 00 01 00 00 00 T...............0012fa8c 00 00 00 00 00 00 00 00 - 10 00 00 00 00 00 00 00 ................0012fa9c 30 00 00 00 01 00 00 00 - 00 00 00 00 00 00 00 00 0...............0012faac 78 fa 12 00 24 02 0d 00 - 14 fb 12 00 8f 04 44 7e x...$.........D~0012fabc 30 88 41 7e 00 00 00 00 - 24 fb 12 00 cd 89 41 7e 0.A~....$.....A~0012facc 00 00 00 00 53 0f 41 02 - 24 02 0d 00 13 01 00 00 ....S.A.$.......disassembling:[...]00523ddc push eax00523ddd push 000523ddf lea eax, [ebx+$34c]00523de5 push eax00523de6 mov eax, [ebx+$3ac]00523dec > mov eax, [eax+$10]00523def push eax00523df0 lea eax, [ebx+$344]00523df6 push eax00523df7 lea eax, [ebx+$354]00523dfd push eax[...] 5.4 Work fine for me. But I love 5.6 more Edited May 17, 2009 by kyosan1988 Link to post
logster 0 Posted May 19, 2009 Report Share Posted May 19, 2009 Hey guys. New here.I downloaded XWD and I think it's awesome. However, whenever I restart my computer or restart the dock, some of my custom icons get a screwed up, and things move around.Is there any way to save the dock's info?Moved to a more appropriate area, try using the search function too this problem has been mentioned a few times - mps69 Link to post
Parmazan 0 Posted May 22, 2009 Report Share Posted May 22, 2009 Hi...I just installed Xwindows Dock today and am having trouble organising my icons on the dock...how do I change the order the icons appear on the dock?Thanks Link to post
Memophysic 0 Posted May 23, 2009 Report Share Posted May 23, 2009 Hi...I just installed Xwindows Dock today and am having trouble organising my icons on the dock...how do I change the order the icons appear on the dock?ThanksSimple as a blink, just drag&drop!That's the technology! Link to post
risemix 0 Posted May 25, 2009 Report Share Posted May 25, 2009 (edited) This software has been nothing but trouble for me.I've tried the suggestions in the FAQ and in this thread, but still:I cannot see labels.I cannot drag and drop items on the dock.There are no animations.In addition,Dragging a window toward the bottom dock causes my rig to slow down to levels I've never seen before. It has something to do with the reflections, but when I turn them down/off, I still have the problem.This is after closing all other programs and adjusting the settings as best I can.Overall, this software is quite buggy and "unrefined" at best. I understand that the author has chosen to suspend work on the project, which is a shame because there seems to be quite a bit of work that needs to be done before this is even usable compared to similar software (many of which are also free).Anyhow, it's a nice piece of eye candy and if nothing else the artwork and customization are really fantastic.EDIT: I want to apologize for this post, as I did manage to get the software working with a quick reboot and edit of a few registry entries. Thanks for the lovely software. Edited May 25, 2009 by risemix Link to post
btb42693 0 Posted May 25, 2009 Report Share Posted May 25, 2009 (edited) @risemix, What OS do you have? Much of your description sounds like common Windows 7 problems. Have you tried running and installing the program with administrative rights? That seems to clear a lot up with many people. One solution that helped me was to install the program in a different folder such as your documents folder. Try basic troubleshooting, i.e. turning off reflections (like you said you did) and change the opacity of the dock to 100%, no transparency. Keep turning off many features slowly and continue restarting the dock ad try to find the problem. A lot of eye candy that this application has can use a lot of resources, such as memory and CPU. Depending on your graphics card, it can sometimes run a little funny on old cards. On your next response, include your system details including processor speed, memory capacity, graphics memory, etc. So that we can figure out a solution better than what I've told u so far EDIT: After reading your update risemix, go ahead and forget my post Registry cleaning software does also help clear up some errors with this software also. Some good cleaners are: CCleaner by Pitiform, Glary Utilities by Glarysoft, Registry Mechanic by PC Tools, and Registry Booster by Uniblu, just some suggestions to software that are safe to use and work very well for me. The last two require paid subscriptions to work completely, so use the first two for free. They work just fine and work with all versions of Windows including Windows 7. Just google them to find them. Edited May 25, 2009 by btb42693 Link to post
risemix 0 Posted May 25, 2009 Report Share Posted May 25, 2009 I do in fact use Windows 7 and the software runs great with the latest RC. However, it should be noted that I did try the software on Vista and had the same problems. I made sure of that before reporting the issues. With that said, it would be wise to try to find someone who can update the software for a Windows 7 release, or this Dock will be obsolete in less than a year. That's assuming you guys still have the source etc. I'm incredibly happy with this. Best dock I've used, that's including the retail version of ObjectDock. By the way, Stardock is a really hard company to deal with. Link to post
xandir112 0 Posted May 26, 2009 Report Share Posted May 26, 2009 how to make the dock not affected by show the desktop? Link to post
risemix 0 Posted May 26, 2009 Report Share Posted May 26, 2009 Hi, guys. A quick follow-up on my old post:XWindows Dock will not function in Windows 7 if you have enabled background cycling. It will also cease to function correctly if you, at any point while it is running, change your background image. In order to get it to function after changing your background image, you must close the program, log off and back on (or reboot) and start it again. If you have background cycling enabled at all, XWD's animations, labels, and drag and drop functionality will cease functioning after a few seconds.I hope this helped somebody. Link to post
mija 0 Posted May 27, 2009 Report Share Posted May 27, 2009 Hi there - i can't help it but... for some reasons XWD slows down my system lots - (dual core [email protected] 2GHz) and always 25 to 30% CPU load / 50MB RAM what is no fun at all. What´s wrong - is it just me or...? Link to post
btb42693 0 Posted May 27, 2009 Report Share Posted May 27, 2009 @mija,It could be a number of things that could be slowing your system down. Try to turn off some eye candy such as window reflections, transparency, stack caching, etc. In the options menu of the XWD, there are some options you can turn off that can greatly reduce the amount of CPU usage or RAM usage the program is using. It is stated on some of the options that it will take a lot of RAM or CPU usage, so uncheck those and see if that helps. Also, take note that the higher quality you use for your images, the more CPU usage and RAM it will take when you are using the program. If the program is constantly running at 25-30% CPU usage constantly WITHOUT hovering your mouse over it, then that could be a different problem. However, with all the eye candy on, it should be normal to take that much CPU usage when hovering your mouse over the dock, because my processor is pretty close to yours, speed-wise. How much RAM do you have? I would suggest having at least 2 GB of RAM to use with your system if it is Vista or Windows 7, just so that your system runs nice and smooth with this program. Link to post
mija 0 Posted May 27, 2009 Report Share Posted May 27, 2009 @btb42693Hmm thanks for the quick reply. I "played" some with my settings - but for some reasons there is no big effect on my CPUload. No reflection, transparency, stack caching... But it´s maybe all my png's - i have about 70 icons on my dock - 128x128 up to 512x512 some. I´m on 4GB or better 3GB RAM and "old school" XP SP3 *winks*here a pic of my task manager and XDW --> http://img7.imageshack.us/img7/5570/xwd.png ) Link to post
