vmart3 0 Posted March 31, 2009 Report Share Posted March 31, 2009 Okay so i just got a web cam and im having problems using it with any other programs besides the one it came with. For instance cmaroid.com or even the photobooth clone on this website. Im pretty sure it may have something to do with flash idk but whenever i try to go to website that needs access to my cam i click allow and then the browser crashes and with the photobooth clone i just see any video/picture or it will say a problem occured and has to close. I have a logitech quickcam fusion if that helps. Its fustrating cuz i just bought it and i cant even get it to work with anything besides the default program it came with. Please help Me!! Link to post
holo13x 0 Posted April 1, 2009 Report Share Posted April 1, 2009 try re-installing, or get an update for the web camera Link to post
vmart3 0 Posted April 1, 2009 Author Report Share Posted April 1, 2009 I tried that just now still doesn't work Anything else i could try Link to post
ibenia 0 Posted April 3, 2009 Report Share Posted April 3, 2009 See if you are having the updated versions . Link to post
matonga 0 Posted April 3, 2009 Report Share Posted April 3, 2009 Try the webcam in another computer. If it works there then the problem is in your computer.If it doesn't work in other computer too, try some program such as VirtualDub (File > Capture), VidCap, AMCap, etc... and see if it works with your cam (if it works then it is an issue between your webcam and Flash).If the problem is only with Flash, you'll have to contact Genius (Genius is Quickcam's manufacturer?) Logitech and/or Adobe (Flash's owner currently). Link to post
deathmedic3rd 0 Posted April 3, 2009 Report Share Posted April 3, 2009 you can also do a google search to see if other people have had the same issue Link to post
vmart3 0 Posted April 5, 2009 Author Report Share Posted April 5, 2009 thanks guys i will try this stuff out and let you know if they worked Link to post
vmart3 0 Posted April 9, 2009 Author Report Share Posted April 9, 2009 Okay guys i tried it out with AmCap and it worked great but still doesn't work with internet programs that ask for access to my camera nor does it work with the photobooth app still. So does this mean its a flash problem? Link to post
Guest ceejay77 Posted May 23, 2009 Report Share Posted May 23, 2009 I had similar problems installing I removed and reinstalled and it worked although quality is poor,bad purchase this one I think. Link to post
matonga 0 Posted May 23, 2009 Report Share Posted May 23, 2009 Just by chance, do you happen to have a TV video board too? I had similar problems when trying to use my webcam, because flash would try to use the tv capture board instead. Link to post
vmart3 0 Posted May 24, 2009 Author Report Share Posted May 24, 2009 i called logetech about it and they said its not the camera's fault and then a week later they came with an update that fixed the problem. =) I love that photobooth clone. My mac emulation is now complete!! Link to post
johnmac35 0 Posted June 9, 2009 Report Share Posted June 9, 2009 I think You have to try on other computer or laptop if it works then there is a problem with your webcam and flash also. Ad link removed - mps69 Link to post
