djdanster 0 Posted January 31, 2008 Report Share Posted January 31, 2008 I downloaded a mac os x transformation pac thing frompatrickgs.pa.funpic.debut when i install it and restart my computer it just has the windows classic themewhat have i done wrong and please guide me to getting it right.using windows vista ultimateTHANKSDan Link to post
Björn 0 Posted January 31, 2008 Report Share Posted January 31, 2008 You have to install the uxtheme-patcher, so you tweak windows to accept other msstyles than the original ones.http://www.osx-e.com/downloads/utilities/patcher.html Link to post
djdanster 0 Posted January 31, 2008 Author Report Share Posted January 31, 2008 i241.photobucket.com/albums/ff136/daniellukenorton/unhappy.png^^^^^please view pic urlnewer version? Link to post
davidsword 0 Posted January 31, 2008 Report Share Posted January 31, 2008 cause your running vista. uxtheme is for xp. (always state what OS your running when dealing with software issues), youll need vistaglazz (does the exact same as uxtheme) & you can find that on google. Link to post
djdanster 0 Posted January 31, 2008 Author Report Share Posted January 31, 2008 cause your running vista. uxtheme is for xp. (always state what OS your running when dealing with software issues), youll need vistaglazz (does the exact same as uxtheme) & you can find that on google.it does nothing to the theme lol Link to post
bobbypk86 0 Posted April 21, 2008 Report Share Posted April 21, 2008 use vistaglazz to patch uxtheme for vista. Link to post
Jasica Smith 0 Posted April 30, 2008 Report Share Posted April 30, 2008 I love to solve your problem but i don`t understand that what is the problem with you and your computer actually? Link to post
