[help] Firefox Tabs
You should be able to, there doesn't seem to be a big difference in versions.
Just make a backup of your profile just in case.
EDIT: Tried it and imagezoom, add bookmark here, and web developer were disabled.
But those were the extensions I'd bumped up to 1.4..
By the way, its 1.4.1 now.
i currently have that enabled on my firefox by modding the config file. simply type in the address bar "about:config" (Without quotes), then in the filter's bar type browser.tabs.showSingleWindowModePrefs.
Enable this from False to True.
After doing this go to firefox options and another option should come up under the Advanced tab called "Force links that open new windows to open in", then select "new tab".
Taken from Tweakguides.com http://www.tweakguides.com/Firefox_1.html
@ kaloyster, I used the Deer Park release before, but have since gone back to 1.0.7 (the latest "stable" release). I would try the tweaking stuff that was mention, but I'll wait 'till there's a final on it. Maybe, when i'm bored, i'll look at the info provided by drudragon. (thanks for the info in advance, dru)
