mimeryme 0 Posted August 3, 2004 Report Share Posted August 3, 2004 I created this thread to pool information, in the hopes of finding a solution to a problem which plagues a minority of users.The problem is that the weather configs available for SysStats do not seem to fetch the data. Instead of displaying the temperature value and the weather icon, we are instead shown '%s' and no icon whatsoever. (We have edited configs to work as it should; image paths, zipcode, etc have been edited according to instructions and advice provided on A-S.)If you are part of this minority, please post any relevant information which may help solve the problem. Things such as internet connection, shell used, SysStats host program installation path (e.g. AveDesk install) and method, and other possibly pertinent items. (Since, I probably will miss some myself, I'll update my entry as others post data as well.)Connection: Cable modem - Toshiba with D-Link routerShell: BB4WinOS: Windows XP Pro w/ sp1 - updated w/ all Critical updatesFirewall: KerioPF 2.1.5Host path: d:\utilities\AveDesk\ - fresh zip installSysStats path: \Docklets\SysStatsXMLmeter's URL: http://xoap.weather.com/weather/local/11208?cc=*&unit=eOther: I've tried some troubleshooting.Seeing if it works with ObjectDock. (no)Moving SysStats from \Docklets to \Desklets.Verifying Weather Docklet works. Verifing XMLmeter's URL works.Loading AveDesk only with a SysStats weather config.Using zipcode or USNYXXXXTurned off KerioPF.Removed AveDesk from Kerio's safelist and checked to see if it tries to connect when using a weather config. (it doesn't) Link to post
herd 0 Posted August 3, 2004 Report Share Posted August 3, 2004 Hi,1.Verify that you have msxml4.dll in your Windows\System32 folder. This has beensaid a few times on this board so use the search feature for its whereabouts.2.Verify that you can ping aqua soft or any other web page from the command line.In that case you won't need 1.hth Link to post
mimeryme 0 Posted August 3, 2004 Author Report Share Posted August 3, 2004 I'm good at both fronts: msxml4.dll exists in the system32 folder and I can ping aqua-soft.org just fine. Link to post
NilColor 0 Posted August 3, 2004 Report Share Posted August 3, 2004 I have this problem too i have msxml4.dll can ping aqua-soft.org !! can't ping xoap.weather.com !! but http://xoap.weather.com/weather/local/11208?cc=*&unit=e working in browser... And? what i must to do? XP-Pro SP1, LAN inet (don't know details... i'm not admin) /edit But Weather docklet for OB (not via SysStat) working good... Link to post
Dirty Ole 0 Posted August 3, 2004 Report Share Posted August 3, 2004 Originally posted by NilColor@Aug 3 2004, 03:45 PMI have this problem too i have msxml4.dll can ping aqua-soft.org !! can't ping xoap.weather.com !! but http://xoap.weather.com/weather/local/11208?cc=*&unit=e working in browser... And? what i must to do? XP-Pro SP1, LAN inet (don't know details... i'm not admin) /edit But Weather docklet for OB (not via SysStat) working good... <{POST_SNAPBACK}> Same here mate.I even mentioned this to judge but he was 'idle' at that time and didn't reply. Link to post
Cerebral 0 Posted August 3, 2004 Report Share Posted August 3, 2004 Originally posted by NilColor@Aug 3 2004, 06:15 AM!! can't ping xoap.weather.com !! but http://xoap.weather.com/weather/local/11208?cc=*&unit=e working in browser... <{POST_SNAPBACK}> Some sites are configured to not reply to ping requests. Since you can access it in your browser, I'm thinking that's the case for xoap.weather.com Link to post
NilColor 0 Posted August 4, 2004 Report Share Posted August 4, 2004 Originally posted by judge@Aug 3 2004, 06:02 PMOK. I just tried Neowin's RSS feed and get the same result as you all do with weather.com. So I might stand a chance of sorting this out now.Caio - Judge<{POST_SNAPBACK}>Hope it's will be soon :naughty: But don't hurry. Well job can't be done quickly :smartass: Link to post
Converse 0 Posted August 7, 2004 Report Share Posted August 7, 2004 Praise the Lord! It finally works! :rule: I've been fighting with this for days. Thank you very much Link to post
mazorax 0 Posted August 7, 2004 Report Share Posted August 7, 2004 Worked for me. Thanks a million.....Maz Link to post
AndreasV 0 Posted August 7, 2004 Report Share Posted August 7, 2004 Finally the SysStats weather widgets work :woot: :bow: to judge. Link to post
Manyk 0 Posted August 7, 2004 Report Share Posted August 7, 2004 @judge ... mine has worked fine so far ... is this updated com REALLY necessary if the older one isn't broke for me? Link to post
mimeryme 0 Posted August 8, 2004 Author Report Share Posted August 8, 2004 I still have the issue where the background image of the config won't even load w/ the newer Meters plugin. I also tried using Explorer as my shell w/ the original Meters plugin and the latest one. Oh well.If it works for everyone else who had a problem, it must be just on my end. Good to see it works for a few more now though. Link to post
Blade 0 Posted August 8, 2004 Report Share Posted August 8, 2004 finally the Duckie + Deadzombie weather widget works!Thanks (again) judge! Link to post
Ghostwalker 0 Posted August 8, 2004 Report Share Posted August 8, 2004 Same here always worked for me ...is this update needed? Link to post
mimeryme 0 Posted August 14, 2004 Author Report Share Posted August 14, 2004 I've since tried updating to sp2 on top of my current install, but the problem was still present. I then formatted and installed a slipstreamed sp2 update and all is well.The format probably cleaned up whatever it was that prevented the meter from updating correctly.Thanks for all your help judge. Link to post
XalCore 0 Posted August 20, 2004 Report Share Posted August 20, 2004 Thanks judge! I'd almost given up hope on getting weather docklets to work. You rule dude!!! Link to post
Lupin 0 Posted November 12, 2004 Report Share Posted November 12, 2004 judge: that shockwave flash file fixed it. you're the man! (after fricken 4 hours editing .ini files left right and centre and it turns out NOT to be that or my (limited/lack of) knowledge of AveDesk! - only been using it 24 hours bloody shockfile... grr. those who made weather small, weather medium, weather big, weather mini -- it all looks good now with numbers on them, i was starting to see "%s" even when i wasn't looking at my computer screen) gg. Link to post
A.K.R. 0 Posted November 19, 2004 Report Share Posted November 19, 2004 Argh... I still can't get the icon to display! Link to post
waski 0 Posted November 23, 2004 Report Share Posted November 23, 2004 judge is Great! Works for me toooooo thx Link to post
Faneramx 0 Posted January 27, 2005 Report Share Posted January 27, 2005 hi i want to use in my avedesk sysstat weather widget , crad not farenheit...how to config??? Link to post
ajmicek 0 Posted March 31, 2005 Report Share Posted March 31, 2005 oh thank the lord indeed I googled into this page, I had been wrestling with this problem for weeks since it went down at about the same time as everyone else's. anyhow, that spl file fixed it and I am extremely grateful to judge - good lord I just might donate lol. sunny and 57 here Link to post
dw2004 0 Posted April 1, 2005 Report Share Posted April 1, 2005 It didnt fix my issue. All I get is s% now. Is this supported throught an http proxy that doesent use the default port (mines uses 3128) Thats all I can think of that might be wrong.Pls help Link to post
jggame 0 Posted April 1, 2005 Report Share Posted April 1, 2005 wtf ? what are you 2 talking about, this post is from august of last year, and systats 2,54 is around, so why you don't consult an updated thread? Link to post
dw2004 0 Posted April 1, 2005 Report Share Posted April 1, 2005 Whoops my mistake.. Anyways im using v2.54 Link to post
reload 0 Posted April 1, 2005 Report Share Posted April 1, 2005 ugh mine i just got the temperature working but it cannot show the location Link to post
