[help] Milk Suite V0.3 Weather Widget
esortm
I have installed the Milk Suite V0.3 Weather widget and I am running it with Samurize 1.5. It will not update the weather conditions (icons and text). It appears to have downloaded the info when I setup the config initially, but no further updates will occur. If anyone can provide any assistance, it would be greatly appreciated. Thanks in advance.
A screenshot taken @ 9:30 pm on 5/21/04
The weather widget uses torsius' weather 2004 plugin and I'm not totally sure what the update interval is, but it does update regularly.
Anyway to check whether the widget is broken:
1) Exit any and all Samurize instances,
2) Go to C:\Documents and Settings\[username]\Local Settings\Temp (or your equivalent) and delete the 'Weather.2004' folder. then restart the widget.
Hopefully that should make it work, if not i'd recommend posting a bug report at the samurize forums.
