(help) Infoweather And Infomedia
BAM
Hy all, tried for first time samurize today, but i got 2 prob.
no more prob with infoweather :6
The second prob is for infomedia, again, infomedia work well, but the control key dont work.
Dont know why ??, they tell me a error whem i push play, next....
BIG JPG ....
So, can you help me with this 2 error plz, tks.
And finnaly, can you tell me how to have this 2 config start auto on windows. For 2 configs, need 2 samurize, so the shortcut in startup folder wont work i think, will be 2 shotchut of the last config, in example, if the last config is infomedia, the 2 shorcut will lunch 2 infomedia when windowns will start.
Tks for the help, sorry for my bad english
Have a good week :canadian:
i can't help you with this problems :( i'm not a specialist in scripts:(
to have 2 configs at the same time , open one of the configs>file>merge>put the other config you want. and save the changes
reload config and that's all :D
try to put this winamp.exe in your samurize/scripts folder ;)
it should works.
to make start specific config of samurize with windows:
make .vbs with this scripts:
Set WshShell = WScript.CreateObject("WScript.Shell")
set oShell = CreateObject("Shell.Application")
strSamPath = WshShell.RegRead ("HKCUSoftwareSerious SamurizegeneralDirPath")
SAMURIZE_DIRECTORY = strSamPath
KillClient
Wscript.sleep (100)
Set oExec = WshShell.Exec(SAMURIZE_DIRECTORY & "Client.exe " & """i=instance name""")
Set oExec = Nothing
Set WshShell = Nothing
Function KillClient
Dim objWMIService, colProcessList, objProcess, PID
  Set objWMIService = GetObject("winmgmts:.rootcimv2")
  Set colProcessList = objWMIService.ExecQuery("select * from Win32_Process where CommandLine LIKE '%Client.exe%" & "tabs" & "%'")
  For Each objProcess in colProcessList
    PID = objProcess.ProcessID
    killPID(PID)
  Next
End Function
Function killPID(PID)
Dim WshShell
Set WshShell = CreateObject("wscript.shell")
WshShell.run "taskkill /PID " & PID, 0
End Function
change instance name by the names of yours configs,launch it and load the config.
then make shortcuts of these scripts and put it on your start folder of your startpanel(don't know the english name of this folder,it's the folder where you put the shortcuts that you want to be launch with windows.for sur it's in the start menu"all programs")
