Timan Posted October 31, 2009 Report Share Posted October 31, 2009 For the iPhone/iPod Touch, Android, Palm Pre and BlackBerry!* * May work on other -webkit enabled devices Screenshots: Last Updated: 05/18/10 Note: This is not a free skin, you can purchase it here. Live Demo: http://www.vastyles.com/ipb3/ You must be on a Mobile device to see the skin. Installation instructions, for Invision Power Board 3.x You MUST import both of the xml.gz files. (Templates/aqua-soft-mobile.xml.gz and Images/as-mobile.xml.gz) First Login to the admin panel of your forum. Select the Look & Feel tab at the top, and then click on Import / Export in the left menu. Scroll down to where it says Import Skin Templates. Browse for the Templates/aqua-soft-mobile.xml.gz file and press Import Skin Set Once the skin templates are done importing, go back and Import the Skin Images using the Images/as-mobile.xml.gz file. Before you press import, make sure the Aqua-Soft Mobile Skin is selected for the skin set to use the images with. When you've done that, press Import Image Set After you are done importing both the skin set and image set, click on Manage Skin Sets & Templates in the left menu. Then click Edit Settings to the right of Aqua-Soft Mobile. Make sure your settings look like the following. Once done, it save. Note: To get the skin to load for iPhone/iPod Touch/BlackBerry/Android and Palm Pre users you MUST set the skin to those user agents. Click on Manage Skin Sets & Templates in the left menu. Then click Manage User Agent Mapping to the right of Aqua-Soft Mobile. Scroll down and check the web browsers you want to use with this skin, then click Save. For Palm Pre and Android users see this post http://www.aqua-soft.org/forum/index.php?s...st&p=532869 Note: Make sure the IP.Board Lo-Fi skin does not have the iPhone, iPod Touch & BlackBerry user agents selected. If you feel there are any templates you think maybe missing, do let me know. It is easy to overlook certain sections of the forum. A lot of time has been put into this skin. I ask that you do not redistribute this without permission. If account is found link'd to a redistributed version of this skin, they will be banned and lose access to future version. And lastly feel free to donate. Heres a simple video walkthrough on how to import and set the user agents. [media]http://www.youtube.com/watch?v=Cd-kyfVQiak [media]http://www.youtube.com/watch?v=mXIYUA3u1wg IPB3 Aqua-Soft Mobile.zip Link to comment
Timan Posted October 31, 2009 Author Report Share Posted October 31, 2009 Updated 10-31-09- Fixed onlinelist not displaying correctly- Fixed registration question & answers- Removed Galleries/IP.Content from search results (since they are not mobile ready). Link to comment
Timan Posted November 3, 2009 Author Report Share Posted November 3, 2009 Updated 11-02-09- Removed IPB.Pages search results (since they are not mobile ready).- Removed Gallery from UCP (since they are not mobile ready). Link to comment
Timan Posted November 29, 2009 Author Report Share Posted November 29, 2009 Updated 11-29-09- Added Portal (Portal tab will replace the Home tab if it is setup in the settings)- Added Modification for user to toggle back and froth between mobile and non-mobile skins.- Fixed JS so you can link to posts without it scrolling to the top.- Slight CSS Tweaks Link to comment
Timan Posted November 30, 2009 Author Report Share Posted November 30, 2009 Updated 11-30-09 - Added Android Support (1.6+) Note: You "must" replace the images (see mobile folder) and update the css (nav & search) for this to work. To add detection for Android, add the user agent with the following. Updated 12-31-09 - Added Palm Pre (webOS) Support (1.0+) To add detection for Palm Pre (webOS), add the user agent with the following. Link to comment
Timan Posted December 31, 2009 Author Report Share Posted December 31, 2009 Updated 12-31-09- Added BlackBerry Support- Added Palm Pre (webOS) Support- Added popup alert for new private message- Fixed Images in posts breaking the width of the site- Fixed Lists and Misc BB Code bits- Fixed Contact Form- Added Shoutbox "Read Only"- Made it easier to change the logo (simply change the mobile/header_logo.png image)- Made it easier to change background and font colors (at the top of the ipb_styles.css, you can't miss it)- Various other fixesYou MUST import the images again, there are new images for the palm pre and blackberry devices. Link to comment
Timan Posted January 2, 2010 Author Report Share Posted January 2, 2010 Updated 01-02-10 - Added Missing Images (3: t_unread.png, t_hot_unread.png, t_poll_unread.png) Link to comment
Timan Posted January 9, 2010 Author Report Share Posted January 9, 2010 Updated 01-09-10- Added Support for Global Forum Message hook (http://community.invisionpower.com/files/f...um-message-100/)- Added Support for Members Online Today hook (http://community.invisionpower.com/files/f...line-today-100/)- Added Support for Guest Message hook (http://community.invisionpower.com/files/f...st-message-140/)- Added App Icon & Splace Image for users who want to set your forums on their home screens. Example PSD Included (mobile/icon.png & mobile/splash.png)- Added BBCode.txt for those who want YouTube viewable on their iPhones- Added Help- Added Memberlist- Added Advanced Search- Added Mark Forum as Read to the bottom of forums- Added Forum Leaders, Top Posters, Online List, etc- Added Topic and Forum subscription- Added confirm logout for those who press it by mistake- Added Control Panel bits for the following...- - Attachments- - Announcements- - Forum Pref- - Avatars- - Photo- - Ignored Users- - Member Look Up- - IP Address Look Up- - Watched Forums- - Watched Topics- Fixed Forum tab for users with Portal set as default- Fixed avatars on profiles for Facebook, Gravatar and Local users- Fixed missing post background-color- Fixed formatting issues in Help and Guidelines- Fixed error messages- Removed current unsupported ipb addon's from the control panel and search results- Removed shoutbox hook when disabled- Tweaked ProfilesAttached are new images, they are also included in the skin package.01_09_10_images.zip Link to comment
Timan Posted January 14, 2010 Author Report Share Posted January 14, 2010 Updated 01-14-10- Added IP.Blog 2.1 (currently rc2) Support- Added Skin Chooser when user has selected a skin on the mobile device. (Will stay hidden if user just allows ipb to do its magic)- Fixed images on BlackBerry devices- Fixed Online List bug not showing forum or linking to user profileAdded Images (for blog support)These must be in /public/style_images/as-mobile/blog/blog.zip Link to comment
Timan Posted February 2, 2010 Author Report Share Posted February 2, 2010 Updated 02-02-10- Blogs updated to Final Version- Moved View New / Active Posts to the top of the forum index- Added view "my content" when logged in. (your posts and topics)- New posts will now take you to the last unread- If more than 25 users in the online list, it will show a link to view the online list rather then displaying them all.- Add reply will take you to quick reply if enabled (less page loading on the go)Can view a list of extra user agents to add in this thread herehttp://www.aqua-soft.org/forum/topic/53567-user-agents/ Link to comment
Timan Posted February 2, 2010 Author Report Share Posted February 2, 2010 Updated 02-02-10- Repackaged skin, blogs and shoutbox should now be imported correctly. Link to comment
Timan Posted May 18, 2010 Author Report Share Posted May 18, 2010 Updated 05-18-10- Fixed when posting a blog entry, will now show the correct date instead of (Nov 19th, 1999)This update is only needed if you use the blog add-on on your site. Link to comment
