Bebi_Bulma Posted July 8, 2009 Report Share Posted July 8, 2009 I've been using TheWeather desklet for ages, and all of a sudden it's no longer giving a read-out, as if my internet connection is down (which it's not). When I go to the link that is used in the config (which is here) it gives me the following error:<error><err type="14">Missing XOAP 'link' parameter in request.</err></error>I haven't changed anything in the config, it just started doing this yesterday. Is there a way to fix this to get it working again? Thanks. Link to comment
mps69 Posted July 8, 2009 Report Share Posted July 8, 2009 Don't think your alone. After a bit of hunting this might explain things,here Link to comment
Bebi_Bulma Posted July 8, 2009 Author Report Share Posted July 8, 2009 Yeah I read about it on some other forums too, blah! Link to comment
Hp329 Posted July 11, 2009 Report Share Posted July 11, 2009 Has anyone seen any update on this subject? My weather desklet isn't working either, so I'm assuming all SysStats weather desklets are being affected by this, no? Link to comment
shirilover Posted July 12, 2009 Report Share Posted July 12, 2009 (edited) You will need to change the url for the xml feed to include &link=xoap&prod=xoap.This should fix the error that you're seeing.On a side note, the extended forecast is only the current + next 4 days.Or, you can change the url to reference xml.weather.com instead of xoap.weather.comThis method will keep the extended forecast as it was. Edited July 12, 2009 by shirilover Link to comment
FusionXP Posted July 13, 2009 Report Share Posted July 13, 2009 Mine no longer works either. I tried entering a different address but it still doesn't work. Anyone know a fix? Link to comment
Bebi_Bulma Posted July 17, 2009 Author Report Share Posted July 17, 2009 Or, you can change the url to reference xml.weather.com instead of xoap.weather.comThis method will keep the extended forecast as it was. Awesome, this worked for me. Link to comment
FusionXP Posted July 17, 2009 Report Share Posted July 17, 2009 (edited) So what exactly has to be copied over. I tried changing the URL and it's not working. Please give an example.EDIT: I got it now. I was changing the wrong URL.Thanks Edited July 17, 2009 by FusionXP Link to comment
