BOBAH13 Posted January 17, 2009 Report Share Posted January 17, 2009 Here is the new XWindows Dock 5.4: you should install new version to a new folder, but you can try to copy DockItems.xml. skins have a new format, so all previous skins must be re-generated (they're NOT compatible!) run XWD with default skin, then look into .SkinsCurrent folder for examples of new PNGs that are needed. docklets have a new API, so all previous docklets developers will have to migrate them before they can be used again. Features Two types: 2D and 3D. Supports many languages. Not yours? Add it via an XML file! Skin-able. You can also create your own skins (and even borrow images from other skins)! *Improved!* Can be started with windows. Size of icons: 32x32 to 100x100 pixels Configurable zoom of icons when mouse hovers over them: 32x32 to 100x100 pixels. *Improved!* Configurable number of zoomed icons. *New!* Has built in stacks. Four modes are available: fan, grid, list and it's unique gallery mode! *New&Improved!* Selectable animation for stacks. *New!* Configurable number of icons in fan stacks: 4 to 30. Configurable number of icons in grid stacks: 1 to 200. Configurable spacing between icons and their reflections: -5 to +5 pixels. Configurable spacing between icon and bottom of dock. *New!* Configurable opacity and blur of reflections. *New&Improved!* Configurable panel opacity: 0 to 100% Configurable panel hiding time: 0 to 3600 seconds *New!* Configurable space between panel and screen border: 0 to 100 pixels Configurable space between icons: 0 to 10 pixels. Shows indicators of running applications. Option to hide stacks when losing focus. Option to minimize windows into dock. Supports 2 effects: Default and Genie. Configurable minimization speed. *Improved!* Folder monitoring. Configurable for reacting to events such as: Added, Removed, Modified and Renamed files. Option to remain always on top. Configurable size of icons in stacks: 24 to 150 pixels. Option to show icon shadow, and to define opacity and blur of the shadow. *New&Improved!* Option to show dock on mouseover. Two options for what to do when an icon is dragged out of the dock: create shortcut or removal. And many more! New stack type: Gallery, where you can look trough your pictures, videos and other files. You can also play a video or install your picture as wallpaper. To change position of playing video just type either the right or left arrow key. To activate item of gallery click either the left or right mouse button. What's the purpose of Mask*.png files in a skin? They're used for determining how to show windows reflection on the panel. If you don't want that the dock shows relfection on some places of your skin panel, you should use 100% transparency. You can also create reflection gradients. For that you should create gradients from white to black or from black to white . Black is used to instruct the dock where reflection should be painted, while white is where it shouldn't. For a better understanding of it, you should unpack some skins from .Skins and look at what its mask*.png files look like and then see the resulting effect when running the dock. If you wish to say thanks, please do it here. Link to comment
atreiu Posted January 18, 2009 Report Share Posted January 18, 2009 Hi everyone, I want to inform you about the status of my Docklets, concerning the fantastic update to XWD Version 5.4. * No Docklet for 5.2.3 does work under 5.4. Don't try it. (Hehe, now you will try it, won't you?) * There have been a lot of changes in the underlying API, so it will take a while, till i have updated all these Docklets. Also I don't just want to update them, but take the chance to build in some minor improvements & suggestions. So please be patient. The Docklets will probably be updated in ~ this order: XHarddrive, XMail, XCal, XDesktoplet, XGrab, XCmd, XBattery, XVol. They will be published in the new Docklets for v5.4 - Thread (replaces the old sticky? Panta?). I can't give you a timeline, sorry. * I decided to publish the sources, when ever it's possible, to help other developers create new Docklets, and to help other people help me to improve my Docklets (your patches are very welcome!). I will included the source directly into the usual downloads, they are only some kb big and I save time, when I don't have to pack them seperatly. In the Docklet-Thread you will see, which files are essential, so you can delete the others, if you urgently need some more kb free space on your drive . * I try to get away from the Mac-Dock like look for my docklets, for two reasons: First, I'm not sure about the legacy of the Mac-Icons I used before, and second I will support Bobahs efforts to clearly seperate from Mac-Dock. However, there will always be enough options for customization... Cheers, Atreiu. Link to comment
Nikola Posted January 18, 2009 Report Share Posted January 18, 2009 Good work! But i was hoping that you will put option to minimize window without effects but... Link to comment
atreiu Posted January 18, 2009 Report Share Posted January 18, 2009 Good work! But i was hoping that you will put option to minimize window without effects but... I miss that option too, Nikola, but not every suggestion and improvement can be done in one Update So let's be happy about the things that already have been improved. BTW: We all should think about donating to Bobah, for his efforts! (Where are your donating-infos gone, Bobah?) Link to comment
Nikola Posted January 18, 2009 Report Share Posted January 18, 2009 I miss that option too, Nikola, but not every suggestion and improvement can be done in one Update So let's be happy about the things that already have been improved. BTW: We all should think about donating to Bobah, for his efforts! (Where are your donating-infos gone, Bobah?) you are totally right.This is big progres,XWD become highly customizable dock with no concurrents on the milles away ; ) Link to comment
nodeffect Posted January 19, 2009 Report Share Posted January 19, 2009 just a quick question, can I use 5.3 skins on 5.4 ? Link to comment
suckingfaces Posted January 19, 2009 Report Share Posted January 19, 2009 just a quick question, can I use 5.3 skins on 5.4 ?5.3 skins aren't compatible, sorry dude. You can try porting some from 5.3 to 5.4 using matonga's skin editor, but be prepared to make grid edges and masks for new ones. Link to comment
atreiu Posted January 19, 2009 Report Share Posted January 19, 2009 Just want to announce, for the once who didn't already noticed (like me ) XWindowsDock is on aqua-softs Frontpage with a nice article: http://www.aqua-soft.org/board/news.php Congratulations, Bobah! Link to comment
freestart Posted January 20, 2009 Report Share Posted January 20, 2009 Hi,I have converted all 135 skins of the version 5.2.3 for the new version 5.4; it has been a hard job; I hope that BOBAH13 doesn't add new changes of compatibility to the skins in the next versions here for download:http://www.aqua-soft.org/board/showthread.php?t=51164NOTE: I am not the author of the skins, I have converted only their, I apologize me with the authors if they were in disagreement with this job. Link to comment
Panta Posted January 20, 2009 Report Share Posted January 20, 2009 @freestart: I know you did it with the best intentions in mind but, as the new version has new graphic elements, I don't think it's a good idea publishing your personal conversions, as the authors may have different ideas about how they should look. Let them do their job for publishing... Link to comment
Mattey Posted January 20, 2009 Report Share Posted January 20, 2009 @freestart: I know you did it with the best intentions in mind but, as the new version has new graphic elements, I don't think it's a good idea publishing your personal conversions, as the authors may have different ideas about how they should look. Let them do their job for publishing... Man, if you think twice, you should know it is NOT a bad idea. As you said: ...the authors may have different ideas about how they should look.Let them do their job So if those authors have new ideas, WE are the ones who must choose the best skin. Those new ideas might be an update for THIS skin repack!!! Link to comment
Panta Posted January 20, 2009 Report Share Posted January 20, 2009 @Mattey: As far as I know, he has no permission for reworking and republishing them; obviously he can rework them for his own use.Sooner or later we're going to have problems for publishing unauthorized skins and icons! (as I've already been warned by a friend...) Link to comment
Byakkun Posted January 20, 2009 Report Share Posted January 20, 2009 @Mattey: As far as I know, he has no permission for reworking and republishing them; obviously he can rework them for his own use.Sooner or later we're going to have problems for publishing unauthorized skins and icons! (as I've already been warned by a friend...)Make some rules for this problem.Something like: Do not post anything you "modified" if you have not changed/edited all the skin elements (more or less the masks) or you have permission to use it (which you should get on a public internet space be it a forum, dA or other sites/blogs comment) from the author himself. Anyone who doesn't respect this rule should be warned/banned/denounced. Link to comment
atreiu Posted January 20, 2009 Report Share Posted January 20, 2009 Make some rules for this problem.Something like: Do not post anything you "modified" if you have not changed/edited all the skin elements (more or less the masks) or you have permission to use it (which you should get on a public internet space be it a forum, dA or other sites/blogs comment) from the author himself. Anyone who doesn't respect this rule should be warned/banned/denounced.No additional rules needed here, everything is already in the Board Policies:4.3. Action: Pirated software, pornography of any kind or copyrighted content will NOT be allowed.Result: Post will be deleted or have the offending content removed.That says everything.BTW: It's not clear, if the themes he posted are copyrighted or not, or if he has permission or not. So it's totally up to him. It's on his responsibility, anyway. I run a board for my own, so I know the legal impact: Everything someone posts is on the posters responsibility ONLY. The owners of the Board are not obligated to check everything for copyright, but they are obligated to delete obviously illegal content or as illegal reported content within 24hours. (this is the law in Germany)PS: The Board Policies are strange in this case: they should say:4.3. Action: Pirated software, pornography of any kind or illegal posting of copyrighted content will NOT be allowed.Result: Post will be deleted or have the offending content removed.Because everything the people post on this Forum is automatically copyrighted to them, f.e. shishimaru has automatically the copyright of his great designs, until he decided to stand back from his copyright by using a GPL or something. But there is nothing wrong, if a copyright holder (Bobah or shisimaru) decide to post their material here.PPS: If further discussion is needed, i propose to use another thread, because this is getting off topic. Link to comment
freestart Posted January 20, 2009 Report Share Posted January 20, 2009 Man, if you think twice, you should know it is NOT a bad idea.As you said:So if those authors have new ideas, WE are the ones who must choose the best skin.Those new ideas might be an update for THIS skin repack!!!yes I understand and I am sorry for it, I have not thought about that. I am sure that they will release even more new beautiful versions. Link to comment
Layer Cake Posted January 20, 2009 Report Share Posted January 20, 2009 @freestart: I know you did it with the best intentions in mind but, as the new version has new graphic elements, I don't think it's a good idea publishing your personal conversions, as the authors may have different ideas about how they should look. Let them do their job for publishing... A good point for you. I didn't wanted to talk about this subject but it was in my mind. You are totally true. I see a lot of WILD ports here (BUT i'm not talking about xwd 5.2.3 skins to 5.2.4). Link to comment
Panta Posted January 21, 2009 Report Share Posted January 21, 2009 Hi folks! For a week or so the poll How Skins should be kept will be running. this is your chance to help organizing the sub-forum and also to be heard! Please, don't just vote but also tell us what you think! Link to comment
yorkey Posted January 21, 2009 Report Share Posted January 21, 2009 Hey Guys, Can someone help and fix the link? the installation link was not working ;( thanks you! can someone upload it some were else coz my server is forbidding me plz http://www.mediafire.com/download.php?4yl2ze2lmid (thanks zequihumano for the link) Link to comment
Austin123 Posted January 24, 2009 Report Share Posted January 24, 2009 Boba how do I donate? Link to comment
Panta Posted January 24, 2009 Report Share Posted January 24, 2009 @all: last call for voting at How should skins be kept?The poll will be closed today! (Jan/24) Link to comment
BOBAH13 Posted January 24, 2009 Author Report Share Posted January 24, 2009 Boba how do I donate? Sorry and thanks But now you can't, because I live in Ukraine may be in future somebode will decided to help me.... Link to comment
username3d3 Posted January 24, 2009 Report Share Posted January 24, 2009 Sorry and thanks But now you can't, because I live in Ukraine may be in future somebode will decided to help me.... Did you ever talk with Denis700? I believe he said he lives in Poland. Not sure how he would get the money to you, but you should try him, because I really want to give my thanks also. Hope you get it working soon dude, really. Link to comment
atreiu Posted January 24, 2009 Report Share Posted January 24, 2009 One of the most popular German Tech-Blogs, "Caschys", reports about XWindowsDock 5.4. http://stadt-bremerhaven.de/2009/01/24/xwi...n-54/#more-7890 (Google-Translate is your friend ) Quote: "I think it's the best dock, known as freeware for Windows operating systems that exists." Link to comment
Panta Posted January 25, 2009 Report Share Posted January 25, 2009 @all skinners with individual download threads: This is the result of our poll "How should skins be kept?" . Only one, centralized, sticky, release-only thread where you can find all published skins: 24 votes, 80.00% . Many scattered, non-sticky, open for commenting thread; many skins can be published: 6 votes, 20.00% . Voters: 30. This confirms that the single, centralized thread approach is, by far, the best for our users. This way, in order to conciliate this user-friendly approach with the skinner's desire of receiving feedback, I ask you to do the following: 1. Create a post at Skins and Support Files for v5.4 (if you already have a post there, just update it) and put your download link only* at this post; 2. Remove the download link from your individual thread; 3. Insert at your thread a link to your post at the Skins thread. This way both necessities are contemplated! I hope having this sorted out by the end of Jan/26. *About posting at both threads: I'm afraid it'll only make things more confusing than it's needed. Even if you manage maintaining both posts synchronized (more work for you...), nothing assures me that others will do the same (more work for me!) and besides, if you keep a direct link from your thread to your release post at the 'Skins and Support Files for v5.4' thread, whoever finds your thread will also find your skins. This is almost the same thing - will work almost like before - but will greatly help me keeping things organized in the long run. I'm pretty sure I can count on your comprehension and support! Cheers, Panta. Link to comment
Panta Posted January 26, 2009 Report Share Posted January 26, 2009 @all skinners with individual download threads:After midnight tonight (GMT - 2:00h) I will lock and block downloading from all skin threads that were not adapted by then!Please, take a time for updating your threads to the new system; for now, only username3d3 has adapted some of his threads... :slant:Thanks! Link to comment
