Start Menu Problem
#1
Posted 04 August 2011 - 09:18 AM
#2
Posted 10 August 2011 - 09:29 AM
jhfuies, on 04 August 2011 - 09:18 AM, said:
I have Vista and it works just fine except one problem: I can't modify start menu privacy options in the taskbar and start menu properties, every time I select those chekboxes and click apply windows deselectes them and as a consequence no word or excel files are remembered by windows to have been modified.
Hello I don't have vista but I have many problems with my start menu too.Find with a hotbot "windows vista start menu" and you will find many sites whose dedicated to all sorts of vista start menu problems.Bye
#4
Posted 16 February 2012 - 11:10 AM
Well, Do ur user account have the rights to modify these setting or it is a member of administrator group.
or it is affected by Trojans that the reasons u are not able to set up the privacy settings.
First u need a good anti virus for ur system, full scan ur system. After the scan complete u have to repair repair ur windows.
#5
Posted 19 March 2012 - 10:33 AM
well, are you affected by virus, the activity you talks indicates the virus.
Do you have the anti-virus installed in your system. You need the virus removal software to remove virus from your system.
Sign In »
Register Now!
Help
MultiQuote
