Question On Dock System As I Have A 64Bit Comp
Recruit
1
12-December 10
Posted 13 December 2010 - 08:58 AM
I loaded this dock system as it was the only one that seemed to work with my Win7 64bit system. I can't seem to put folders on my dock. They work first of all then when I have rebooted they don't work. Can I control my comp with it by putting 'Start' on the dock so as it replaces the task bar/ Also not all softwares respond from the dock when they are working. At present I have DVD flick working and it doesn't respond when I click it, I have to go to the task bar. I have tried several dock systems and this is the only one that worked sort of to how it should be. Others failed miserably. Or, is there a Dock system that is for 64bit systems? I love the dock but its not working to what I hoped it should do. Is there a way that I can get an icon on the dock to expand or open up to a doc I had been working on. For instance I am writing a book, on the task bar I hover my mouse and it shows me previous documents I have been working on. My Icons I use for my folders don't stay either and it won't allow me to chose the icon from the window system.
Its functional and looks nice but it doesn't do what I could do on the taskbar.
Looking forward to seeing your replies
Developers
465
06-September 08
Posted 13 December 2010 - 10:08 AM
May in next version I will try to implement Buttons and Previous Docs (like in Windows 7 taskbar/menu) funcionality in the dock. Right now not sure, thanks for interesting issue.
