Aqua-Soft Forums: Flyakite And Other Application Issue - Aqua-Soft Forums
Flyakite And Other Application Issue user32.dll solution Rate Topic: -----
#1 User is offline   romand Icon
  • Group: Recruit
Posted 01 May 2010 - 04:56 PM
there are a lot of post over the internet talking about installing flyakite and having problems loading vlc video lan media player ,open office , windows calculator (calc.exe) and other applications
after many wrong solutions, and no help from Microsoft I decided to uninstall flyakite because I can't work without open office or vlc. When the uninstaller launched I decided to look what I'm uninstalling and by surprise I saw under System Files Shell32. Yes, of course some functionality lost, but almost everything stays the same so try it. Solved my issues.
for lazy ppl that can't read so much ( or laughing at my Israeli English ) here is step-by-step:
1. Go to uninstall.
2. Start uninstalling flyakite.
3. You will see that you can choose what do you want to uninstall - leave everything unchecked except System Files->Shell32 - check only Shell32.
4. Reboot.
#2 User is offline   KAWSquared Icon
Posted 15 May 2010 - 03:57 AM
Flyakite is ridiculously out of date - just in case no one who has recently installed it has noticed. The last version was released, what... 3 years ago? 4 years ago? Come on now. It's a death wish for your computer.
#3 User is offline   rakibim007 Icon
  • Group: Recruit
Posted 13 July 2011 - 09:38 PM
God bless you romand !! THANKS A LOT ! :)
My all problems is fixed :)
#4 User is offline   bSAYZ Icon
Posted 14 July 2011 - 02:36 AM
use Lion skin pack :rolleyes:
#5 User is offline   rpliego Icon
Posted 14 August 2011 - 10:51 PM
I continue using flyakite but a very old version of 2004 where you had to make the things almost manually.
from winXP I make the changes to my win7 files, it doesn't work directly on win7 :(
these were the instruccuiones to continue:
In the root directory of BATCHMOD are several Windows NT command scripts which you can use to mod your files. If you want to do all required steps in one go, use auto.cmd, if you prefer the step-by-step approach, use the files in this order:
1. copy.cmd - Copies moddable files from your Windows and Program Files directory to the _IN folder. (Required on first time use, or after updating Windows)
2. extract.cmd - Extracts Resources from all files inside the _SOURCE folder. (Required on first time use, or when you change any files in the _SOURCE folder)
(2a. OPTIONAL STEP - If you wish to translate your system files or change the dialogs/menus/strings you can use extract_language.cmd to extract language-related resources from files in the _SOURCE folder. You have to change the extracted .res files in the resources folder yourself using reshacker or a similar tool, this process can NOT be automated and you need proper knowledge about the format of these resources!)
3. modify.cmd - Modifies files inside the _IN folder with the extracted resources and copies the result to the _OUT folder. (Required step)
(3a. OPTIONAL STEP - To update files in the _OUT folder with modded language resources, launch modify_language.cmd. NOTE: You have to use modify.cmd FIRST otherwise there will be no files in the _OUT folder!)
4. replace.cmd - Backs up and replaces moddable files in your Windows and Program Files directory. (Required step)
After replacing files, you can use restore.cmd to restore your original files should the need arise.
someone remember that version? :P
