Help Center For V5.6
- XWD Forum Moderator
652
16-January 07
Posted 31 January 2009 - 12:36 PM
Ask for help with anything XWD-related (version 5.6) at this thread.
Please, use this thread for asking for support with difficulties you may have with XWD and its components.
Remember looking at the threads for previous versions too and also using our handy search function before posting; your question might be already answered!
Supporters are encouraged to try helping other users but, please, try to stick to supporting, rather than commenting.
This post has been edited by Panta: 01 March 2009 - 04:20 AM
- The XWD Enthusiast
531
06-September 08
Posted 31 January 2009 - 05:05 PM
How to you make skins with the new version? I'm getting all confused :S
Edit: nevermind, I got it
93
17-December 07
Posted 31 January 2009 - 05:08 PM
downloand link is still not working, archieve is corrupted
531
06-September 08
Posted 31 January 2009 - 05:13 PM
try to clear your internet cache. It's working here.
93
17-December 07
Posted 31 January 2009 - 05:22 PM
i mean rar file can be downloaded but cant be extracted, can you?
531
06-September 08
Posted 31 January 2009 - 05:24 PM
It's a zip file o_O are you sure you're downloading the right link?
93
17-December 07
Posted 31 January 2009 - 05:35 PM
yes it is .zip[sorry] but one should be able to extract with Winrar, right.
531
06-September 08
Posted 31 January 2009 - 05:42 PM
I was able to extract with winrar... have you tried redownloading again?
152
01-October 08
Posted 31 January 2009 - 08:17 PM
Hey there ppl!
Got a question...
On last version (5.4) I was able to see .rmvb videos thumbnails on stacks, but now in 5.6 I also can, but not all of them, just a few, .avi are ok, but like in the screenshot, the first one it´s an .rmvb, the the other bunch with the question mark are .rmvb, an the other few with thumbnail are .avi, and the winamp file there it´s an mpg and i was also able to see it, so what´s the prob? why I can´t see all the .rmvb thumbnail, I already added the extension on the files tab and re-installed the codecs.
Thanks in advance!
531
06-September 08
Posted 31 January 2009 - 08:23 PM
skdj;522422 said:
Hey there ppl!
Got a question...
Thanks in advance!
Might you give the filenames of the rmvbs that work, and don't? Any differences will help nail this bug, which I think this is
152
01-October 08
Posted 31 January 2009 - 09:30 PM
First of all thanks for answer so fast, well there´s a lot, but as you can see on the thumbnail, the first one that´s 12 monkeys it´s an .rmvb, aaaaall the other ones with question mark are .rmvb also, and those few with thumbnail are .avis,now since I wrote on the other post, I ran the past version of XWD to see if it was the current version, and surprise! they´re gone too!
What´s wrong!?
Hope it´s clear what im writing...
531
06-September 08
Posted 31 January 2009 - 09:33 PM
What´s wrong!?
Mmm... I'll have to let Bobah answer this one. For now, try renaming one of your not-working files to the same as a working file, and see if it works. Also try the other way around, and post back
152
01-October 08
Posted 31 January 2009 - 10:03 PM
Ok, im on it and i´ll let you know! THX!
652
16-January 07
Posted 31 January 2009 - 10:12 PM
skdj;522440 said:
...now since I wrote on the other post, I ran the past version of XWD to see if it was the current version, and surprise! they´re gone too!...
Then, it seems that something at your PC has changed since the last time it worked - with the previous version of XWD.
As bobah told you before, as far as XWD is concerned, if you have the right codecs in place, and have set .rmvb extension at the right place - at video - as you're telling you have, everything should work; check what you've been doing lately...
152
01-October 08
Posted 31 January 2009 - 10:22 PM
Yep, that´s why im asking, cause that time I asked BOBAH I installed those codecs and then it worked, so with this version I installed XWD, then I re-did the stack with the rmvb files, i checked them, and they where like when I asked BOBAH in first time, so, I re installed the codecs and they still the same, I´ll try with some other codecs, think it will work?
56
13-April 08
Posted 31 January 2009 - 10:24 PM
I really don't know what is wrong with mine, I don't have any labels and they are turned on, and I don't have any magnification. I also can't drag item, I can only drag them off of the dock.
I am on Vista 32-bit....I have re-installed many times to different folders and all kinds of stuff, any suggestions?
14
25-January 09
Posted 31 January 2009 - 10:34 PM
Cant find download link
531
06-September 08
Posted 31 January 2009 - 10:36 PM
http://narod.yandex.ru/100.xhtml?nemecsx.n...ckInstaller.zip
click on the bolded link after that.
14
25-January 09
Posted 31 January 2009 - 10:44 PM
AndrewYY;522463 said:
it wont let me download it it says
Failed to Connect
Firefox can't establish a connection to the server at nemecsx.narod.ru.
also tried it on i.e
could u upload it to a different website
11
29-October 08
Posted 31 January 2009 - 10:45 PM
I have same probleme like you iJesse ! hope some one help use!
Ihve this error when i start WXD first time :
By Panta: please avoid reproducing images within quoted messages.
