Aqua-Soft Forums: Flyakitesosx Problem With Vlc Media Player - Aqua-Soft Forums
Flyakitesosx Problem With Vlc Media Player Rate Topic: -----
#1 User is offline   dtrobson099 Icon
  • Group: Recruit
Posted 12 February 2010 - 07:26 PM
I'm having a problem getting VLC Media Player to work now that I've installed FlyakiteOSX v3.5. Below is the error text:
vlc.exe - Illegal System DLL Relocation
The system DLL user32.dll was relocated in memory. The application will not run properly. The relocation occurred because the DLL C:\WINDOWS\system32\SHELL32.DLL occupied an address range reserved for Windows system DLLs. The vendor supplying the DLL should be contacted for a new DLL.
Any insight would be appreciated.
#2 User is offline   firecracker6 Icon
  • Group: News Posters
Posted 12 February 2010 - 10:56 PM
not much insight to offer you at this time but a workaround.. http://portableapps....eo/vlc_portable
See if you can run a portable version of VLC..
Your problem may have something to do with using the 128 large icon option when installing the flyakite. Did you select this option during setup?
#3 User is offline   dtrobson099 Icon
  • Group: Recruit
Posted 12 February 2010 - 11:06 PM
Thanks - I think I did use the 128 option. Any way to undo this without completely uninstalling or going back to my restore point? I'll give VLC mobile a shot too.
Edit: Quickly trying out VLCPortable, it gets through the splash screen with no errors, but fails to play a video. No error, it just never brings anything up.
I'm thinking maybe I'll dump everything to a USB drive and try this again on a fresh install of Windows XP Media Center if all else fails.
This post has been edited by dtrobson099: 12 February 2010 - 11:33 PM
#4 User is offline   ggmanyak Icon
  • Group: Recruit
Posted 24 April 2010 - 11:21 PM
i think your vlc crashes when you install a theme in you XP machine (longhorn/vista inspirat,FlyakiteOSX v3.5?)..
if you do have theme, just uninstall it. and your vlc will work just fine.
This post has been edited by ggmanyak: 24 April 2010 - 11:24 PM
#5 User is offline   romand Icon
  • Group: Recruit
Posted 01 May 2010 - 04:57 PM
try my solution:
http://www.aqua-soft...lication-issue/
#6 User is offline   dianne100 Icon
  • Group: Recruit
Posted 20 October 2010 - 10:04 AM
I have Windows XP Black Edition and using the FlyakiteOSX v3.5, there is no problem with my VLC player. Why don't you try changing the OS first?
#7 User is offline   rakibim007 Icon
  • Group: Recruit
Posted 13 July 2011 - 09:39 PM
quote
romand
1. Go to uninstall.
2. Start uninstalling flyakite.
3. You will see that you can choose what do you want to uninstall - leave everything unchecked except System Files->Shell32 - check only Shell32.
4. Reboot.
