Shoutbox is not working on my site via the mobile skin, although the buttons are there etc.
Few Questions Mobile Skin
#1
Posted 22 January 2010 - 02:31 AM
#2
Posted 22 January 2010 - 02:51 AM
Did you install shoutbox and m30 guest message "after" you imported the skin?
To hide the anonymous login bit is really easy
Login Screen > showLoginForm
Remove this bit from the template
And that should do it.
<li class="input"><input type='checkbox' id='invisible' name='anonymous' value='1' title="{$this->lang->words['form_invisible']}" /></li>And that should do it.
#5
Posted 23 January 2010 - 07:39 PM
Timan sure, I appreciate the help, the forums are http://forums.azsportsbikecentral.org
#6
Posted 27 January 2010 - 04:01 AM
I'm having the same issues with the shoutbox, everything is there but it doesn't work, you can't "shout"
http://forums.platformnation.com
Sign In »
Register Now!
Help
MultiQuote
