Navbar Display Problem If Minimized
Subscribers
2
07-October 07
Posted 21 January 2010 - 03:07 PM
I added a couple of icons in the Navbar and now everytime I sort of decrease the size of the browser window it somewhat breaks the Quick Links and the Logout button, see image below:
Is there a code that I need to add in the Navbar template to make the Icons in the Navbar in place? or put specific width to the forum perhaps?
TIA.
Administrators
4,741
08-November 02
Posted 22 January 2010 - 02:52 AM
Only thing I can suggest is you set the min-width of your forums to be wider. Or remove some of the toolbar icons (min-width should be 990~px anyway, which should fit that).
Subscribers
2
07-October 07
Posted 28 January 2010 - 08:17 AM
thanks for the feedback Timan, manually puttinga custom min-width didn't work. Had no choice but to remove one toolbar icon for it to be fixed.
Thanks again.
