Followers 0
Massive Amount Of Problems For Avedesk 1.4
DirectX   4 votes
  1. 1. Should AveDesk have DirectX 10+ support?
    • Yes
      3
    • No
      1
Please sign in or register to vote in this poll.
4 posts in this topic
OK, so I'm new to AveDesk. When I tried to install it, it sayd a file called d3dx9_36.dll was missing. It is a DirectX 9 dll, only found in version 9, and I have 10, I believe. So, I had to go to DLLFiles.com and download the dll. Now, it works (sorta). Whenever I add multiple desklets, they overlap, and the ones behind can't get out of the front one's borders. So, all of the desklets are practically trapped in the first one. I don't want to downgrade DirectX because that would cause some problems with the programs I have, and this problem is getting REALLY annoying. And the desklets that are behind others don't work, except closing (done only through Control Panel). If anyone has a solution, PLEASE POST, AND VOTE.
Share on other sites
I'm using Avedesk 1.4 in Windows 7, no stability issue yet.
I'm sorry, but this is about DirectX. It's really annoying when some programs don't have DirectX 10+ support. Some old games don't, and some people say even if you downgrade, it causes errors.
You don't have to "downgrade" to get directx games to work. Windows 7 simply doesn't include support for dx9.
That means when you install it, dx9 installs aside dirextx 10/11, it doesn't overwrite that functionality.
Edited by kalkal
Create an account
Register a new account
Sign in
Followers 0
