Thank you, MPs
69!
..not really an installer .. (
thanks for clarifying for me).
Well, i first installed the "
LeopardXP_BricoPack_by_nobodyuse.exe" PACK (which includes several programs to let Windows face of MAC, including the RK Launcher).
After installing, I was changing some settings in RK Launcher .. then it stopped working ... I then restart Windows. The RK Launcher does not appear, but in the Task Manager, the process had RKLauncher.exe.
Then i exclude the original folder
C: \ Program Files \ RK Launcher and I downloaded the RK (you showed me). Thus:
C: \ Program Files \ RK Launcher ... containing the new files.
I started the RK Launcher manually
but nothing appeared. So did the test:
1: I changed my display settings to 800x600
2: Then, I returned to 1024x768 and the black bar RK "appeared (as in picture attached). When I click the button "minimize" in any window, made the transition as if everything was normal but, this transition goto this 'black bar'.
Also changed to 16bits but does not work =\.;
in the folder 'RK Launcher'.. the file icons.conf is null (i open it with notepad). Normal?.;
Thanky Again =D.;
This post has been edited by rbackspin: 08 July 2009 - 03:31 AM
