Aqua-Soft Forums: Why Does Rk Launcher Keep Dissapearing? :( - Aqua-Soft Forums
#1 User is offline   TommyM Icon
Posted 02 April 2009 - 10:07 PM
Just installed the proggy the other day and LOVE IT!.
Problem is that whenever I restart my computer it's gone :-(
I installed the program folder in Program Files. So I need to go
to the exe and launch in every time by hand. I also tried making
a short cut on my desktop to the exe so I could launch it from there,
but it won't work that way.
Is there a way to set up my computer so that when I start it, the Launcher
is already there? (I'm guessing that's the way it is meant to work)
Thanks!
-Tommy M
#2 User is offline   Ronno Icon
Posted 02 April 2009 - 11:21 PM
Maybe try adding the shortcut to your startup folder?
Start> all programs> startup
Hope this helps! :)
#3 User is offline   holo13x Icon
Posted 02 April 2009 - 11:27 PM
there is an option in the dock for that, right click on the dock, settings, behavior tab in the window, and there should be checked and un-checked options, at the end, there is one thats says, start with windows, make shure its checked, and ur done.
#4 User is offline   TommyM Icon
Posted 03 April 2009 - 05:27 AM
Thanks holo13x & Ronno!
#5 User is offline   holo13x Icon
Posted 04 April 2009 - 02:19 AM
u welcome, any time man.
#6 User is offline   scwd Icon
Posted 27 April 2009 - 05:04 PM
never mind i figured it out on my own
