Help - Multi-plugin
Help Installing
6
04-March 09
Posted 04 March 2009 - 06:29 PM
ya i just downloaded the Multi-Plugin install 2.5 whatever whatever and i started running it and it installed fine no
problems but when i tried opening up itunes it wouldnt let me!! it says :
The procedure entry point RegOpenKeyW could not be located in the dynamic link library MPlugin.dll
and well idk wat to do!!!
someone pls help me cus i dont wanna go and delete stuff all randomly about it!!
Moved to a more appropriate area and re-titled - thanks mps69
34
22-November 04
Posted 04 March 2009 - 09:13 PM
What version of itunes are you using because multi plugin only works with itunes up to version 7 i think
6
04-March 09
Posted 05 March 2009 - 01:08 AM
oh well i have the very newest one its 8 i think...
ok well so if thats the case then what do i need to do to get rid of it?
like which files do i delete to make it back to normal?
this is what's in my itunes folder:
<a href="http://s280.photobucket.com/albums/kk183/williemino/?action=view¤t=screen.jpg" target="_blank"><img src="http://i280.photobucket.com/albums/kk183/williemino/screen.jpg" border="0" alt="Photobucket"></a>
Do not double post - use the edit function - thanks mps69
2,940
04-December 06
Posted 05 March 2009 - 01:19 AM
Hmm... very interesting and unique case...
This has never happened before.
I don't know what to tell you. Search on the forums maybe. Because I seriously have no idea what to do.
6
04-March 09
Posted 05 March 2009 - 04:21 AM
well if anyone knows what to do pls pls pls message me or reply on this forum cus idk wat to do without my itunes lol!
250
19-July 06
Posted 05 March 2009 - 06:44 AM
(sigh)....
@wonkamino Next time as KAWSquared suggested SEARCH the forums...
For the last time..... Multi-plugin only works with iTunes 7 up to release 7.0.2
34
22-November 04
Posted 05 March 2009 - 01:29 PM
just double click on multi plugin again as if installing it only this time it will uninstall itself otherwise try system restore
6
04-March 09
Posted 06 March 2009 - 03:15 AM
Raats, on Mar 5th 2009, 07:44 AM, said:
(sigh)....
yaaaaaaaaaa i know that now. thats why i said someone pls help me get rid of it
oh and thank you welshdragon
