and I'm having problem with desktop icons.
When I create a shortcut item on desktop for a folder, it works fine.
But if it is shortcut for a file(jpg,avi,txt,etc.), it does not work perfectly.
when I double click on it to open it, an error occurs and it says,
"An attempt was made to reference a token that does not exist."
and to fix this problem, I have to go to Desklet Properties for the item
and put the directory of the file in the Start In on the Shortcut tab.
I was trying to use Desktop Grabber, and I have to do this everytime
a new desktop file was added.
Another problem is when I select the desktop shortcut and press ctrl+c or v or x
an error occurs again and this time it says,
"The file does not have a program associated with it for performing this action. Create an association in
the Set Associations control panel."
There is a part where it says "Desktop Icons not supported" on information for Avedesk 1.4 version.
I wonder if these errors have to do anything with it, and is there anyway I can fix these problems?
Sign In »
Register Now!
Help
MultiQuote
