Aqua-Soft Forums: Taskbar issue Please Help Me.... - Aqua-Soft Forums
Taskbar issue Please Help Me.... Rate Topic: -----
#1 User is offline   ericacemedia Icon
Posted 01 February 2009 - 05:07 AM
Okay, so I installed Flyakite on my PC about a week ago, I love it so much but my problem arose when I installed some windows updates. My taskbar immediatly turned into the old windows style, and I couldn'e get the Mac Style back. I uninstalled Flyakite and reinstalled but to no avail, I still have the dumb windows looking taskbar. I want the Mac one back. I'm a poor Graphic Designer with no money for a "REAL" Mac so this is my closest thing to it. Thanks...
#2 User is offline   username3d3 Icon
Posted 01 February 2009 - 05:40 AM
Maybe it's just your theme or your visual style. Did you make sure that when installing Flyakite that you installed the Tiger Visual Style? Go to your desktop properties after installing and make sure that you still have the Tiger VS checked.
#3 User is offline   mps69 Icon
  • Group: Administrators
Posted 01 February 2009 - 09:05 AM
Depending on the Windows update the UX Patch might need to be done again, especially if the update was for SP3, you'll need to google for that patch.
#4 User is offline   ericacemedia Icon
Posted 17 February 2009 - 04:16 PM
I found that patch and it worked for me before but it now gives me a blue screen unless I do the restore function
#5 User is offline   Elamderek574 Icon
Posted 14 June 2009 - 11:53 PM
You need to install the Universal UXTheme patch. You can find it on CNET downloads. It is compatible with SP2 and SP3, I had the same problem and this fixed everything.
