Aqua-Soft Forums: Help with a few problems. - Aqua-Soft Forums
Help with a few problems. Rate Topic: -----
#1 User is offline   BlueExodus Icon
Posted 14 January 2009 - 09:19 PM
I'm running Avedesk 2 Beta on Windows Vista with the Vista compatibility update installed.
I'm doing OK with this so far, but I have a few problems.
1) PIDLShortcut Sub-Labels - Some of the label options such as Folder Size don't work with vista. I'm sure this bug has been brought to attention, but until it is fixed is there a way to work around it or an alternative shortcut widget which does not have this problem?
2) Sysstats Causing Crash - When sysstats is installed, loading any sysstats docklet causes Avedesk to crash in much the same way as it did before the vista compatibility update. Is there a fix for this?
3) Where can I find themes for AveTunes 5 and how do I install them?
