Aqua-Soft Forums: Help Center - Ask for help ONLY here! - Aqua-Soft Forums
  • 7 Pages +
  • 1
  • 2
  • 3
  • Last »
  • This topic is locked
Help Center - Ask for help ONLY here! Rate Topic: -----
#1 User is offline   blackbelt534 Icon
Posted 28 December 2008 - 08:39 PM
I just started using Xwindowsdock and I have a couple questions:
1.How to you add new applications to the dock?
2.How do you add and use skins?
#2 User is offline   username3d3 Icon
Posted 28 December 2008 - 09:29 PM
1) To add applications just drag and drop the application into the dock.
2) Search for "Leopard skin for XWindows Dock" on Aqua-Soft forums.
The directions to install are in the package. You also have to play around with the settings to learn your way around and to figure what each thing does.
If you have anymore questions, just ask.
#3 User is offline   blackbelt534 Icon
Posted 28 December 2008 - 09:37 PM
Could you give me a download link? I cant seem to find a link in the Leopard Xwindowsdock thread.
and if you can't can you just explain the process of adding and using skins in Xwindowsdock
#4 User is offline   username3d3 Icon
Posted 28 December 2008 - 09:50 PM
He's currently updating v5.2.3 to v5.2.4, it will probably be available tommorow, but just search around for some.
PS: Mattey just released like 25, but I can't find the link
TO add and use a skin extract the skin.smxd file to your skins folder in the XWindows Dock directory, reload the dock and choose the skin from the settings panel.
#5 User is offline   blackbelt534 Icon
Posted 28 December 2008 - 10:01 PM
I ve added to skins to the Xwindowsdock directory but when i go to dock preferences and try to change the skin the only skin I can choose is the default, how do I change the skin?
#6 User is offline   username3d3 Icon
Posted 28 December 2008 - 10:32 PM
In the preferences settings click refresh in the dock settings, if nothing happens then,
1) Make sure you extracted to C:Program FilesXwindowsDockSkins directory
#7 User is offline   blackbelt534 Icon
Posted 28 December 2008 - 10:46 PM
IVe done both of those but it still only shows default as the only skin I can pick
#8 User is offline   username3d3 Icon
Posted 28 December 2008 - 11:18 PM
Well if everything failed, I would reinstall everything and try again. Sorry I couldn't be anymore helpful.
#9 User is offline   blackbelt534 Icon
Posted 29 December 2008 - 12:39 AM
Is there a uninstall module or do you delete the folder containing Xwindowsdock? because everytime I try to delete it I get the error message below
Attached File(s)
#10 User is offline   Björn Icon
Posted 29 December 2008 - 12:42 AM
I hated Vista for things like that...
#11 User is offline   username3d3 Icon
First, exit out XWindows Dock and make sure it's not running in the background.
Next, delete the whole XWindows Dock folder, then reinstall.
I'm also not using Vista so I wouldn't completely know.
#12 User is offline   blackbelt534 Icon
Posted 29 December 2008 - 12:44 AM
Well it read the dock skins you send me, so could it be a problem with the skins I'm trying to use?( could you send me a leopard skin for Xwindowsdock?)
#13 User is offline   username3d3 Icon
Posted 29 December 2008 - 01:01 AM
It won't let me upload for some reason.
#14 User is offline   blackbelt534 Icon
Posted 29 December 2008 - 01:07 AM
could you e-mail it to me?
#15 User is offline   BigBoss Icon
Posted 07 January 2009 - 05:35 PM
Have the same problem...
#16 User is offline   blackbelt534 Icon
Posted 07 January 2009 - 10:50 PM
whats your problem?
#17 User is offline   BigBoss Icon
Posted 08 January 2009 - 10:36 AM
I mean i can't use skins in xwindowsdock. They not appear in change skin option.
#18 User is offline   raesteac Icon
Posted 08 January 2009 - 03:21 PM
My english bad sorry
stack icon blur. Can i fix this? and ı change stack icon but bakground in folder but i didn't want...
this screen... Rk Laucher and XWindows Dock
Posted Image
#19 User is offline   firecracker6 Icon
  • Group: News Posters
Posted 08 January 2009 - 04:18 PM
1. I want to delete this: The 'background' items you wish to delete are the icon images contained within the stack folder, correct? Currently Matonga's Stack docklet provides you the option of only displaying the front 3 icons, thus feeling less cluttered. With XWD, it would seem all icons are shown in a closed stack, even with an 'overlay' stack icon assigned. I believe, currently there is no alternative to this. Your best solution might be to change the contents of your stack folder, or assign less noticeable icons within the stack, (See below.)
2. Icon's blur in XWD is due to how XWD handles windows icons. To fix this blur, right click on the stack icon (firefox) choose EDIT and change the icon with a Firefox.PNG icon. This is currently the recommended solution, I believe.
#20 User is offline   blackbelt534 Icon
Posted 08 January 2009 - 10:33 PM
make sure that the skins are in the XwindowsdockSkins directory, that the skins you are trying to use are for the current version of xwindowsdock, and press the refresh button in preferences
  • 7 Pages +
  • 1
  • 2
  • 3
  • Last »
