Aqua-Soft Forums: [Help] Avedesk conflict with Explorer.exe - Aqua-Soft Forums
[Help] Avedesk conflict with Explorer.exe Rate Topic: -----
#1 User is offline   coolvibes Icon
Posted 29 November 2008 - 08:35 PM
I have Avedesk 1.4 (beta2 dont work for me)
Avedesk is great for the dock and the weather desklet but i have some problem
1. The biggest problem is sometimes when deleting files with permission it crash explorer.exe
so i have to restart explorer.exe to get my tray etc.. back without rebooting
The problem is that everytime Avedesk is running clicking Explorer.exe dont restart explorer
instead this happen:
- the User/documents folder opens
- Everytime i click to re-start explorer.exe a new explorer.exe show up in the background
so it just duplicate explorer.exe but it dosnt realy restart explorer.exe
As soon i Exit Avedesk, close the non-working explorer.exe in the background and re-start explorer
it work again explorer.exe start up
I pointed this down that there must be a conflict between Avedesk and Explorer.exe
Is there a way to fix this , this is so problematic because sometimes i just have to restart explorer.exe
and i dont want to reboot or restart Avedesk everytime i do
Could it be that Avedesk is using some explorer.exe services hence preventing explorer.exe from restarting until avedesk is closed?
2. Another question i have is about the MorphDock for avedesk 1.4
when mousing over a icon : Program label and program route (C:/windows etc..)
is displayed
Is there a way to disable so that the Route (C:/windows etc...) is not displayed
and only the Label name ?
And is there a way to Always show label name not only when mousing over?
3. Also in Morphdock is there a easy way to change possition of a Icon
i tried mousing over the icon and dragging it into new possition but that dont work (like in Rocketdock)
so If i need to have a new icon in certain possition i have to re-configure all icons again ?
4. About Hot weather for Avedesk (i using the first version of the 2) is it possible to change the theme
to say total black instead of having it silver/grey ?
5. Anywhere i can download more Morphdock skins?
or having the Wood skin in other colors (so far i changed it easy into grayscale it look much better
as you can see here:
Posted Image
