Aqua-Soft Forums: Taskbar problems - Aqua-Soft Forums
Taskbar problems Rate Topic: -----
#1 User is offline   xpourtant Icon
Posted 12 October 2008 - 09:38 PM
I installed FlyakiteOSX and everything is working PERFECTLY except the taskbar.. It still has a windows look to it.. I'm using XP Professional.. I wasn't able to find a solution, so if there is one, sorry for reposting..
#2 User is offline   xpourtant Icon
Posted 12 October 2008 - 09:46 PM
Screenshot - http://i35.tinypic.com/33jpblx.jpg
#3 User is offline   Phoshi Icon
Posted 12 October 2008 - 09:57 PM
You'll need to patch your UXtheme, assuming you;'re running SP3, because fak is outdated.
http://www.softpedia.com/progDownload/SP3-...load-98929.html should do it
#4 User is offline   TrevNasty Icon
Posted 22 October 2008 - 09:53 PM
I had the same problem and that fixed it
#5 User is offline   jakers Icon
Posted 30 October 2008 - 03:02 PM
I am having the same problem using Windows xp home with SP3, should I install this patch after I install flyakite or before????
#6 User is offline   Björn Icon
Posted 30 October 2008 - 03:14 PM
After
#7 User is offline   jakers Icon
Posted 30 October 2008 - 03:23 PM
Excellent, thought so!
Thanks for your help guys.
#8 User is offline   Elamderek574 Icon
Posted 11 June 2009 - 10:40 PM
I had the same problem on SP2 and it came back when I updated to SP3
However this patch still fixed everything thanks!
