Aqua-Soft Forums: 1. best avedesk ver 4 everyday use 2: stability issues - Aqua-Soft Forums
1. best avedesk ver 4 everyday use 2: stability issues Rate Topic: -----
#1 User is offline   imnew Icon
Posted 19 August 2008 - 02:54 AM
Hi there.
A little introduction:
I installed and used Avedesk 1.3 + avescripter (weather plugin only) and it was crashing in 1 of 3 cases after in 1-10 minutes after windows boot (it made desktop freeze and all desktop and avedesk items undragable till i kill it with taskman). Even after i turned off weather plugin i was still gettin' those problems.
Later i found avescripter update on official site but now im always getting "Eng program - aveclosebutton" message @ windows shutdown.
I tryed to use 1.4 and installed dx9 library but it loads corrupted widgets. For instance: 1 of 4 pidshortcuts in theme + without text, and tray icon became corupted.
My h/w is: WinXPSp3En P4-3G(HT)/1Gb/Radeon9500.
(I dunno wheter its a bug, so didn't post it to bugs thread).
So now i have some questions for you guys.
1. Which build are you using 4 everyday and can recommend to me?
2. Am i right when installing avescripter and then update to it which i got from avedesk.org or will i need to get the newone elseware? (didn't find it in Avescripter section)
2. Is it always stable or sometimes you're still gettin' errors/freeze/no responce, etc.?
3. Which other progs can do mac-like desktop icons (with size/file quantity measure, etc.) like Avedesk?
All advices, thoughts, etc. are welcome. Thx in advance.
#2 User is offline   evilmnky204 Icon
Posted 19 August 2008 - 03:00 AM
Did you try the 2.0 beta?
#3 User is offline   Ojalord Icon
Posted 19 August 2008 - 10:46 AM
It's supposed to be stable, that is no frequent crashes, freezes etc. Try the 2.0b version as suggested.
As for alternatives, you have Yahoo! Widgets. And DesktopX too. Take your pick. Avedesk used to be the least resource hungry and most stable for me, though since the other apps are in development that might have changed.
#4 User is offline   evilmnky204 Icon
Posted 19 August 2008 - 04:50 PM
You could also give Samurize a try, though I wouldn't recommend it for beginners. It is way more powerful though, and very light on CPU.
#5 User is offline   Phoshi Icon
Posted 19 August 2008 - 05:52 PM
Samurize is awesome. If anyone argues I'll kill you :)
#6 User is offline   imnew Icon
Posted 19 August 2008 - 11:49 PM
evilmnky204
Didn't try it cuz im avoiding using betas cuz a lot of bugs. U mean that its quite more stable than 1.3/1.4?
I used samurize before, but its unable to make such icons with text:
http://img84.imagesh...48238487bi2.png
I wanna to look on other prog that can do that, cuz it seems to me that i'll completely fail with Avedesk in my case.
#7 User is offline   evilmnky204 Icon
Posted 20 August 2008 - 12:46 AM
Samurize can do that, but I guess you're better off with Avedesk. Avedesk 2.0 has worked out well for me, so try it.
#8 User is offline   pcm Icon
Posted 20 August 2008 - 07:54 PM
Hmm... When you got avescript crashing on your computer, what desklet are you using? You mentioned weather, but then you said you removed it and it still crashes?
You should try to use the avedesk 2.0. It should be on the same website.
#9 User is offline   imnew Icon
Posted 27 September 2008 - 01:57 PM
Yep, it was still crashing without any avescripter-enabled plugins.
Firstly i dloaded avedesk 1.3 from an official site (avedesk.org) and it was constantly crashing for me, then i dloaded it from softpedia and it seemed to be ok. Mb im wrong about my conclusion, buy where is the best to get the stable 1.3 build? Avedesk.org is dead now.
And where is to get the lastest avescripter (i found avescripter update - do i need to instal it too after avescripter?).
And do i need to do smth after unpacking and running Avedesk.exe besides deleting languages directory (i don't need it).
#10 User is offline   imnew Icon
Posted 27 September 2008 - 08:05 PM
Btw, do i need to add this to registry? And shat does that options do?
[HKEY_LOCAL_MACHINESOFTWAREMicrosoftWindowsCurrentVersionShell ExtensionsApproved]
"{6DD050D8-FBDF-4562-AB05-8BF879FAE89E}"="AveInst Extension"
"{F756AF2A-EB0E-4D42-9495-B61BD6D99B82}"="AveDesk Preview Extension"Btw
#11 User is offline   imnew Icon
Posted 28 September 2008 - 02:20 PM
I even tryed beta 2.0 with pid shortcuts only (some folders and my comp/recycle)and with no avescripter.
It crashes 1 of 5 times (when im logging on or logging off), but it still crashes.
The same situation is with 1.3, it crashes like 2.0, mb slightly less or slightly more.
Is it only me having such problems?
#12 User is offline   nodeffect Icon
Posted 19 November 2008 - 10:08 PM
omg.... where can i get the version 2.0b ? I cant find it anywhere here ??? all I see is 1.4 1.3
