Aqua-Soft Forums: Rocketdock Stack Docklet: Grid Problems - Aqua-Soft Forums
Rocketdock Stack Docklet: Grid Problems Rate Topic: -----
#1 User is offline   Zodiak Icon
Posted 11 April 2008 - 10:36 AM
Hi there,
im Using the tool Rocketdock on my PC and I have a problem. I added the Stackdocklet to the tool.
The Fan is working fine. But I have a problem with the Grid. I have 2 Displays (TFT). When I klick on an icon which is linked with a Stack Docklet as a grid, the grid opens itsself on the first display. But I want it to open at the second display because there is my Dock.
Here I got a screenshot!
h**p://img3.imagebanana.com/view/geb2sa/Unbenanntfghfh.bmp.png
The grid should open, where there is the icon for it on the second display. But it opens at the right corner of the left display (first display).
Hope you understand my problem!
Looking forward to finally get an solution for my problem ;) greetings...
#2 User is offline   mps69 Icon
  • Group: Administrators
Posted 11 April 2008 - 04:15 PM
I don't believe the stacks docklet has dual monitor support.
#3 User is offline   derWalter Icon
Posted 13 January 2009 - 01:45 PM
I've got the same problem with my to displays.
I always had the Dock on the top of the left screen, while i was working on the right one.
Now i got this AMAZING docklet and the grid always opens on the primary monitor, wich IS the right one.
The fan opens without serious problems. If the fan is opend i cant smooth switch to an other
Stack Docklet, because the whole bar hangs until i click where i think the other button should be afer
zooming in :/
VERY ANOYING!
#4 User is offline   matonga Icon
Posted 16 January 2009 - 01:23 AM
@Zodiak:
Sorry, I had not seen your post before.
Ok, I checked and it is working just fine here at home (I have a dual-monitor setup, even though some of my apps don't support such setup... :)).
What version of Stacks are you using?
Do you have the right side monitor set as Monitor 1, or the left one as usual?
