Problem with Miranda Skin HUD Adium
60
20-February 07
Posted 04 January 2008 - 03:17 PM
This is how my Miranda looks like:
I'm using 0.7.3 Unicode with Modern Clist + IEView + TabSRM etc.
Who can help?
580
13-July 07
Posted 04 January 2008 - 03:31 PM
have you tried to change the setting in "option" ?
60
20-February 07
Posted 04 January 2008 - 03:34 PM
Dunno which setting...
12
26-April 07
Posted 04 January 2008 - 03:38 PM
can you share your skin?
60
20-February 07
Posted 04 January 2008 - 03:40 PM
It's not my skin, you can download it at deviantart...
Need help pls...
76
15-June 07
Posted 04 January 2008 - 08:47 PM
Try this to fix the text
go in miranda options --> contact list --> row items --> text --> uncheck trim long text with ellipsis
60
20-February 07
Posted 04 January 2008 - 09:00 PM
Thanks, new pic:
What now?
60
20-February 07
Posted 05 January 2008 - 09:16 AM
Who is using this skin and which version of Miranda do u use?
Maybe that's the problem?!
187
03-April 06
Posted 05 January 2008 - 09:34 AM
Have you tried checking the option to resize the list automatically, or tried resizing the window manually?
580
13-July 07
Posted 05 January 2008 - 11:09 AM
Just keep on search in that option,here are my setting,I hope it'll work on your,good luck
60
20-February 07
The option "automatically resize" doesn't effect anything.
When I try to resize miranda manually it looks like this:
edit:
@Husaini HB: Thanks, I will try it now...
580
13-July 07
Posted 05 January 2008 - 11:10 AM
see my attachment,please
60
20-February 07
Posted 05 January 2008 - 11:27 AM
Thanks, but it doesn't help...
Can you please make a screen of your settings at "Contact List > Row Items > Text"?
580
13-July 07
Posted 05 January 2008 - 11:41 AM
Here is mine,what do you mean it doesn't help,that option is the only way to get the HUD setting
60
20-February 07
Posted 05 January 2008 - 11:54 AM
I tried all your settings, but the problem still exists...
227
04-February 07
Posted 06 January 2008 - 04:41 AM
Had the same problem. Try this:
Go to Contact > List Row items > Extra Icons tab and uncheck everything, then click Apply and OK.
Hope this helps
60
20-February 07
Posted 06 January 2008 - 09:46 AM
Hope this helps
Thank you very much, it works now...
But there is still a small problem left:
How can I fix it? (the dark-black line)
edit: I fixed it: I had to disable "automatically resize window"
Thanks all...
30
05-March 06
Posted 12 April 2008 - 04:24 AM
I like it
Thank you
150
27-January 08
Posted 11 May 2008 - 12:26 AM
Thanks all...
i have the same problem with the black line. i find it goes away after a few contacts come online
