Running RKLauncher at startup
#3
Posted 14 December 2007 - 11:57 PM
I can,t tick the box to make it start with windows so what i did was
i went to
C:Documents and SettingsAll UsersStart MenuProgramsStartup
(or you can go to C:Documents and Settings(your username)Start MenuProgramsStartup)
(your username) windows username without the () and add a shortcut of
the RK launcher
Note:
If you go to
all users (if any other) on the PC your using will get RK Launcher at startup
i went to
the RK launcher
Note:
If you go to
#5
Posted 20 November 2009 - 06:57 AM
I'm using Windows 7 64-bit. Rk Launcher was working for me and then I restarted my computer. Now I cannot launch the program at all, even though I can see the process running in the task manager. This is so strange. Perhaps it is a 64-bit issue that all of you are also having?
I've discovered the issue, guys. The problem is actually with the stacksdocklet. In order to fix this you either need to (1) get rid of the stacks docklet or (2) upgrade the docklet to the stacksdocklet2.0 version. You can find it by simply searching the aquasoft forums for stacksdocklet2.0.
...Awesome.
Do not double post - mps69
...Awesome.
#8
Posted 01 December 2009 - 08:41 PM
mitdac, on Dec 1st 2009, 08:32 PM, said:
I also encountered error like that . I have tried many way (including check out start up folder...), but i still can't fix it . Who can help me ? ( i am using windows 7 32bit
) .Thanks !
I think you have to appreciate that RKL was only developed with XP first and later Vista in mind.
If it's not starting from the start folder, you might have to either look at adding a registry entry, or starting manually.
Sign In »
Register Now!
Help
MultiQuote
