Experiencing problems with iTunes after installation? Read this!
#2
Posted 12 March 2007 - 06:50 PM
it does alot of things and the thread for it is here . you might want to try searching for it before making new threads, it's the first hit when you search the forum (it was until you made this thread). you can disable what it does and customize it in the preferences and if you want to uninstall, run the installer again
#3
Posted 13 March 2007 - 01:10 AM
riccjohn, your iTunes doesn't work because the version of mPlugin that comes with FlyakiteOSX is for an older version of iTunes. If you're on iTunes 7.0.x, download the version from the following thread:
http://www.aqua-soft.org/board/showthread....ghlight=mplugin
This will prompt you to uninstall the version that was installed with FlyakiteOSX. Uninstall it, and if you'd like the benefits of mPlugin (enumerated in the thread I linked you to), double click it again to install.
However, there's no version of mPlugin out yet for iTunes 7.1 (expect a release sometime soon is my guess). Download the file anyway to uninstall the older version of mPlugin, but don't bother trying to reinstall mPlugin.
//Thread Stickied, Renamed because we keep getting questions like these.
Hope this helps,
Hope this helps,
Posted 10 May 2007 - 11:37 AM
suprneb;455817 said:
is there any way to install FlyakiteOSX without the multiplugin? (maybe something like not checking the box next to MultiPlugin or something?)
Exactly...there should be a box that says something like "iTunes" or "MultiPlugin." Simply uncheck it.
Posted 11 December 2007 - 12:59 AM
yeah i have some problems with opening iTunes with RK Launcher, i have the latest version of flyakite (3.5) and i didn't install the multiplugin... but when i have an iTunes icon in the Launcher, it says that iTunes.exe is not a valid win32 operation...anyway to fix this???
Attached File(s)
#13
Posted 27 May 2008 - 02:11 PM
i need help!
i do not know what to do and i need iTunes urgent!
i am trying to run iTunes but it shows an error message, i uninstall the plugin,
so it says that it cannot find the plugin file.
so i downloaded it again, and same problem.
I just got an iPod Touch today and I was so eager to put all my music on it,
and now i can't access it. somebody help!
Sign In »
Register Now!
Help
MultiQuote
