I give little info in my title,but nothing happens
1
01-December 02
Posted 01 December 2002 - 01:21 AM
I downloaded .65 or whatever the latest version is and that is the first version I have downloaded, I have not downloaded .5 or anything, but whenever I click on the Mobydock.exe, my taskbar at the bottom dissapears for a few seconds then comes back and my statbar at the top does the same and then nothing else happens. I need help!
750
09-November 02
Posted 01 December 2002 - 12:59 PM
Did you download the FULL version with all the DLLs?
82
08-November 02
Posted 02 December 2002 - 01:37 AM
I have the same problem i'am using Y's dock & MobyDock
after a reboot the Mobydock works fine again.
I really hope that Moby will fix this problem in the next update <_<
2
02-December 02
Posted 02 December 2002 - 03:28 PM
I have the exact same problem and restarting my computer does nothing at all to help to fix the problem. I had the same problem with all of the previous versions too. I can't think of anything that would cause this problem. Under task manager the program is still running and eating up cpu time, but there is no visual change. Hope you can help, Hinsight4
849
10-November 02
Posted 02 December 2002 - 03:52 PM
Hi all!
When you see the taskbar disappear for a few seconds... this is absolutely normal.
Try placing the taskbar at the top of the screen and make sure you have 32-bit colour depth.
Good luck!
Ken
