Aqua-Soft Forums: Choices of Y'z Shadow, and the problem of exclusion - Aqua-Soft Forums
Choices of Y'z Shadow, and the problem of exclusion Rate Topic: -----
#1 User is offline   dronex Icon
Posted 01 October 2006 - 05:20 AM
Hello, everyone. I am now using FlyakiteOSX 3.5. An I am also using Y'z Shadow, too!
I want to ask 2 questions here:
1 - I am quite bad that I just only want to see the shadow enabled on the taskbar, but not other windows. Is that possible to adjust the shadow only available on Taskbar?
2 - Um, since I am a HongKonger, I have to type Chinese as the communcation to my friends. But, sadly, I am not familiar to the default typing method of the Microsoft's original settings. So I bought some other easier typing program that let me able to type well. But everytime when I start up, (Well, there is a taskbar icon for that typing program) There is a shadow appeared at the right upper corner! Well, that make me evertime I have to disable, and re-enable Y'z Shadow that make me feel quite annoying> And that program doesn't have a Window that I can't use the magnifier in Y'z Shadow to disable the unknown shadow..... So, do I need to type something in the script, or any kind of adjusting? Because that is jst becuase of that typing program that makes the desktop ugly.... Oh yes, I found an article which is about Q9 Input, and that is what I use to type Chinese in my computer, but I think the information is not quite enough... http://en.wikipedia.org/wiki/Q9_method
Thanks for any help!
#2 User is offline   realitybath1 Icon
Posted 01 October 2006 - 07:37 AM
If you only want a shadow on your taskbar but not other windows, just photoshop a shadow template which you can add to your wallpapers.
that would solve prob 1+2 and eliminate a running program.
#3 User is offline   dronex Icon
Posted 01 October 2006 - 09:13 AM
realitybath1;421730 said:
...just photoshop a shadow template which you can add to your wallpapers...
Well.... about that photoshopping, do I need to make it to every wallpaper that I want to switch everyday? That might make those wallpapers not original, like having the shadow while previewing with Viewers~
