Changing Cities in Weather Desklets
News Posters
1,112
25-March 06
Posted 12 August 2006 - 12:07 AM
So far, I've tried 3 weather desklets: pcm's, AH-Weather and Lucid Weather. I can't get any of them to flip over so I can change the city, so I'm wondering if there's an XML I can edit so I can change the city. Preferably for AH-Weather, but pcm's will do fine.
Thanks,
-Ertai
174
20-April 06
Posted 12 August 2006 - 05:29 AM
With most of these desklets, you can click on some part of the desklet to get a window to pop up so you can enter your zip code (I'm not sure about these specific desklets though) If this doesn't work, you can search through the xml file for something resembling a zip code (not fun) and change it that way.
I hope this helps
617
02-May 05
Posted 12 August 2006 - 04:05 PM
This is the most common error, and I'll be fixing it in the next update. The flipping option is on the bottom right corner of the desklet. You can't see it until you move over it.
Next version I will make it visible when mouse enters the desklet. Less confusing.
There is much editing in XML needed once you flip it over you can type the name of the city and hit the drop down, it will show you the list of citys to pick from.
If you look at the XML of the desklet you will see the "default" value for the city. You can change it there if you know your city, very messy to do it that way.
News Posters
1,112
25-March 06
Posted 14 August 2006 - 01:10 AM
Ah, I've figured out what happened. I can't flip it because I changed the original AveScripter .dll with one Ave gave me so I could run the Yellow Pages widget.
-Ertai
