OSX Finder not going in the right place
16
02-April 06
Posted 03 June 2006 - 10:42 PM
I have installed the Mac OSX Finder from Dobee's Tiger V, and followed the instructions to install the finder. But I can't get it to go to the left. The instructions say to right click on the finder, then set the horizontal position to left, but nothing happens when I do so.
91
09-April 06
Posted 03 June 2006 - 11:00 PM
I think if you drag the dotted lines next to the apple logo to the right, it should work.
2,929
31-August 03
Posted 03 June 2006 - 11:11 PM
ah, sometimes that's a little tricky, and has nothing to do with samurize, but the nature of the windows taskbar. best way to fix that is to drag the taskbar to twice the height it is now. then, just to the right of the left send of the samurize toolbar, click and hold. the cursor should change to the four-arrowed cursor. then drag the samurize toolbar kinda like down-left-up, and it should then be next to the start button. but, it is a little tricky. good luck!
16
02-April 06
Posted 04 June 2006 - 04:50 AM
thnx a lot for the help!! it took a while but now it's perfect!!
91
09-April 06
Posted 04 June 2006 - 10:46 AM
Glad you got it sorted!
16
28-February 09
Posted 26 April 2009 - 05:22 PM
is that objectbar?
646
15-December 04
Posted 27 April 2009 - 01:34 PM
1 User(s) are reading this topic
0 members, 1 guests, 0 anonymous users
