Aqua-Soft Forums: problem with yahoo widgets - Aqua-Soft Forums
problem with yahoo widgets Rate Topic: -----
#1 User is offline   ajuersood Icon
Posted 06 May 2006 - 01:08 AM
i am having problems with my yahoo widgets. The problem is that i by mistake have changed a setting and the widget has become solid now i can't close it and can't even go back to change the setting.
any ides
pls help
thanks
#2 User is offline   Ali C. Icon
Posted 06 May 2006 - 01:56 AM
Uhoh. Sounds like it could have been knocked to float.
Right click the system tray icon and from there, go under widget preferences (or similar) and select the name of the widget that's causing the trouble.
Once there, go under the Window section. Check and make sure that 'Level of Window' is not set at Floating.
Then, to change the transparency back (if needed), adjustthe slider beneath that.
