Problems with AH´s Weather
304
03-February 06
Posted 25 March 2006 - 05:28 PM
Hello
I use AveDesk 1.3 and AveScripter 1.0.
I have installed the Desklet
AH´s Wather and have added into my desktop. And i live in Malmo,Sweden so i write it so in the Settings.
But when i close AveDesk or reboot my PC the Desklet forget my settings and show nothing or just a cloud or a sun. I have tried 10 000 times to enter the data and save the theme; but when i close avedesk or reboot my PC the Desklet forget the settings again. What to do?
When i start my PC the desklet use to look like this:
172
16-April 05
Posted 25 March 2006 - 06:23 PM
I'm not sure about you, but the weather docklet on my desk stopped since an hour and it's still not getting the weather yet, probably something with weather.com
339
29-October 05
Posted 25 March 2006 - 06:29 PM
its the same with every weather widget at me too... q-q
- Douchebag
1,885
28-June 05
Posted 25 March 2006 - 06:43 PM
Same here but, only for current conditions. Could be getting rest from cache. Probably the link.
Edit: That's weird the xml file is coming up fine in FF. Oops, actually in my case all current conditiions are n/a. Weather.com is updating something.
304
03-February 06
Posted 25 March 2006 - 07:15 PM
But I have got this problem for over two weeks now
. I has maybe something to do with that I live in Sweden. All support is better for people in the US I thik.
304
03-February 06
Posted 25 March 2006 - 07:17 PM
I also have the problem with N/A, but the problem i described is probably something else.
- Douchebag
1,885
28-June 05
Posted 25 March 2006 - 07:47 PM
Ballena, I'm in Canada & it's the same. Can you post your code so, that I can give it a test?
Edit: Ok. I just tested for Malmo, Sweden with both AH Weather & Lucid Weather. It worked and might I say your weather forecast is crappier than mine!
My suggestions are:
-Do you have most current AveScripter version?
-Most current xml parser?
304
03-February 06
Posted 25 March 2006 - 09:56 PM
I´m new to this so.. witch code do you mean? Shall I open the script file for AH´s Weather?
I have
this AveScripter version installed, and I think
this one is installed too. But I´m no´t sure. I try to reinstall avescripter.
And the XML Praser, how do I know I have the latest version? where do i see it? and where do I download the latest version?
230
08-January 05
Posted 25 March 2006 - 10:10 PM
It didn't work a while ago but now it's up and running again I guess. I'm using the weather for Umeå (Sweden) and it works fine. I also tried Malmö and it works as well.
So at least you could come to the conclusion that the problem is not with weather.com. And the support for Sweden should be sufficient because it works for me.
9
21-September 05
Posted 25 March 2006 - 10:28 PM
Haha, how funny. I live in Malmö/Sweden and got the same problem. Right click on the desklet after rebot and press "Update Data".
In the middle of something so forgive me for the short message. Hope it solves your problem.
304
03-February 06
Posted 26 March 2006 - 12:18 AM
I will try that tomorrow, I´m to tired for do anything.
617
02-May 05
Posted 26 March 2006 - 05:30 AM
This might be a bug that I have fixed with the upcoming release of scripter. I'll be releasing the latest version of avescripter this week.
I've been working at typing the document and doing a few new sample desklets. I've had little time lately with all that's been going on with stuff.
But It will be released this week. If you want Ballena, I could send you the scripter dll and you could test to see if it fixs it.
304
03-February 06
Posted 26 March 2006 - 10:24 AM
Yup, That would be nice. I can beta test it
Mavisflipp: It did work to press "update data" but it is strenuous to do that every day
- Douchebag
1,885
28-June 05
Posted 26 March 2006 - 04:40 PM
*chuckle* we wouldn't want your finger to get carpel tunnel syndrome now would we?
304
03-February 06
Posted 26 March 2006 - 05:47 PM
Thanks for the support everyone.
304
03-February 06
Posted 27 March 2006 - 05:00 PM
It works again! I´m so glad!
pmc has resolved the problem with a new version of AveScripter. It will be released soon.
