Aqua-Soft Forums: taskmgr problem - Aqua-Soft Forums
taskmgr problem Rate Topic: -----
#1 User is offline   azrael Icon
Posted 26 February 2006 - 05:28 PM
Hi
why i can not use my taskmgr,press hotkey"ctrl+alt+del" there's nothing alert, rightclick menu on taskbar and select "task manager",can't see the taskmgr also,and i run it "taskmgr" system notes that taskmgr is a invalidation Win32 Application .
#2 User is offline   liquidplasmaflow Icon
Posted 26 February 2006 - 07:42 PM
You need to restore the original taskmgr.exe from your Windows disc. The one on your drive must have been corrupted.
#3 User is offline   gtn Icon
Posted 26 February 2006 - 09:40 PM
...or you have some spyware that is blocking access to the task manager to hide itself.
Download Itty Bitty Process Manager - search IBProcMan on google.
#4 User is offline   nightcrawler1089 Icon
  • Group: Administrators
Posted 27 February 2006 - 01:20 AM
Yeah, it's likely the result of a virus or some such. I don't believe this belongs in the Flyakite forum...if you get it fixed and it turns out to be a virus, I'll move it.
#5 User is offline   azrael Icon
Posted 27 February 2006 - 02:21 AM
i'm sorry ,i didn't express myself well in my first message ,my system enviroment is WinXP SP2 with flyakiteOSX 3.0,but when i uninstall the flyakiteOSX 3.0,the task manager comeback to normal
#6 User is offline   irefoy Icon
Posted 27 February 2006 - 07:04 PM
could it be that the taskmanager is in the info part of the taskbar as simple icon?
#7 User is offline   flyakite Icon
Posted 28 February 2006 - 02:49 AM
Try FlyakiteOSX v3.5.
#8 User is offline   azrael Icon
Posted 28 February 2006 - 05:23 AM
ok ,THX All to help me,i solve this problem,my taskmgr.exe have been corrupted,and i copy a taskmgr.exe from other computer.
#9 User is offline   rockum Icon
Posted 02 December 2008 - 10:11 PM
I have the same problem but bringing a copy from another computer didnt help all the menus are still missing.
