Aqua-Soft Forums: Multi-Plugin 2.3 for iTunes 6 - Aqua-Soft Forums
  • (18 Pages)
  • 1
  • 2
  • 3
  • Last »
  • This topic is locked
Multi-Plugin 2.3 for iTunes 6 Rate Topic: -----
#1 User is offline   localhost Icon
Posted 23 February 2006 - 05:18 PM
This thread is outdated, now that iTunes 7 has been released.
Refer to the following thread instead:
Mutli-Plugin 2.4 for iTunes 7
Here is the content of the previous thread:
Changes:
1. Skin colorizing!
From now you can change the hue/saturation of skins.
Note: This feature uses GDI+, and will be disabled if GDI+ is not found.
2. Many skins included by default. The credits to the skinners are in the help file.
3. The Mac OSX skin is closer to the real thing. Especially the Mini Player.
4. The feature of hiding the menu will only hide it - it will still be usable.
5. Button positions are now adjustable using SkinData.ini.
6. A skin developer can now make skins compatible with both left side and right side buttons, and include a different version of the skin for the Equalizer / Mini Equalizer window. The included WMP11 skin is a good example for how to do this.
7. Silent installation switches for the installer. See the help file for more info.
8. The installer will notify you if a process is using iTunes.exe. Now I won't need to remind people they need to close Y'z Dock or such ;)
9. Multi-Plugin will reinitialize itself if you choose "No" in the scripting warning dialog.
10. From now, it's possible to change ID3 tags of a playing track with Foobar2000 passthrough enabled.
11. The "Don't create Unknown Album folders" feature has been fixed.
12. New option added: If you enable the Foobar2000 passthrough, you will be able to listen to your music even after closing iTunes, and if you open iTunes again before the song has finished, iTunes will recognize that the song is playing and will continue playing it normally.
That way, you can mess with iTunes and continue listening to your music ;)
13. Revamped hebrew support. I don't know if it applies to anyone here, but now Hebrew support using Multi-Plugin is 100% automatic and transparent.
14. Another useful feature for skinners and people who mess with iTunes - Ctrl+Alt+Shift+S refreshes the current skin.
A couple of notes to skin developers:
1.
So far, very few skins had the progress bar glitch fix included.
Don't be lazy, just copy the necessary images from the Mac OSX skin.
2. Please check if your skins look good after colorizing, and if some elements look wierd, use the NoColorize option in SkinData.ini to exclude them from colorizing.
3. Don't forget to check compatibilty with both left side and right side buttons.
Requests I couldn't make:
1.
Support Y'z Shadow.
2. Make iTunes show the album art pane only when a song has album art.
3. Bring back the option to change the functionality of music store arrows.
For those who don't know Multi-Plugin, I'll repost the full feature list:
Appearance Options
Skins:
You may choose a skin from the list or choose the default skin.
You may also change the color of your skin using the Colorize button.
If you want to refresh the current skin, you may press Ctrl+Alt+Shift+S in iTunes.
Credits to the following skinners for making the included skins:
ffpsx - VistaXP
gtn - Big Red Machine, Bister, Longhorn Alternative, Longhorn Alternative Dark
kavin - Milk
ToNeR - InspiratSE, LiTunes II, Royal Inspirat SE Blue, WMP 11
Willy - AlBook, V O I D, RulerAGV2
XMAN - Alluvium Magnite, Siro
yangbao_111 - White Alluvium Magnite
Hide the menu:
To resemble the look of iTunes in Mac OSX, you may hide the menu.
To use it again, you can press Alt+F in iTunes, or just click it's previous location.
Also, if you use Stardock ObjectBar, you can use the iTunes menu from there.
Change main iTunes font or title font:
You may enter a font name in the edit box, and it will change the font according to it.
The title font can only be changed if a skin other than "Default" is selected.
Don't show main window in the taskbar and the Alt+Tab window:
Using this option will hide the main window from the Alt+Tab window.
You can choose to hide it always or only when in Mini Player.
Change main window opacity:
Using this option you can make the main window semi-transparent.
Use the slider to set the opacity level you want.
You can choose to change the opacity always or only when in Mini Player.
Note: Selecting this option will make the main window draw faster, even if the slider is set to 100%.
Current Track Options
Change the main window title according to the playing track:
You may change the title of the iTunes main window while a track is being played.
Formatting tags (listed in the help file) are supported.
Copy track information to the clipboard when a track starts playing:
If you check this option, track information, in the format you specify using formatting tags, will be copied to the clipboard when a track starts playing.
Create a file with information about the current track:
Using this option will create a file named CurrentTrack.txt in your iTunes installation folder when a track starts playing.
Export artwork from the current track to a file:
Using this option will create a file named CurrentArtwork.jpg in your iTunes installation folder when a track starts playing.
This file will contain the artwork of the currently playing track.
Note: The file is called CurrentArtwork.jpg, but it's not necessarily a JPEG file. Most programs recognize the image type by it's content, so that should not lead to any problems and it will remove the need for detecting the extension of the file.
Compatibility Options
Allow WindowFX to add a shadow to iTunes:
Usually, Stardock WindowFX does not add a shadow to iTunes. Using this option changes this.
Make programs recognize iTunes as Winamp:
Many programs can get the current track name and artist from Winamp only. Using this feature, iTunes will be recognized as Winamp by most of those programs.
Fix media keys functionality:
Many keyboards have player control keys which don't work well with iTunes. This option may fix the problem.
If one mode doesn't work, try choosing another one. Different keyboards react differently to the modes.
iPod Hebrew Support:
You may use this option if you want your iPod to display hebrew.
In order to enable it, download the latest iPod Updater from http://www.apple.com/ipod/download/, run the Hebrew iPod Updater which can be downloaded using the provided button, and enable the option for iPod Hebrew support.
This Hebrew support solution uses the official iPod Hebrew firmware, so it should not void your iPod's warranty.
Other Options
Don't create Unknown Album folders:
If you consolidate your library and let iTunes organize your music folder, iTunes will make a folder named "Unknown Album" in the Artist folder for tracks that have no Album tag.
Using this option prevent's iTunes from creating those folders and makes it place such files directly in the Artist folder.
Suppress the scripting warning message:
If you have used scripts that interact with iTunes, you may have noticed the warning message that appears when you try to close iTunes and there is a script still running.
Using this option will make that message not to appear.
Note: If you use this option, do not close iTunes when a script is changing track information or does any other writing operations. Doing so will probably result in corrupt files in your iTunes Library.
Change the full screen visual effects resolution:
By default, iTunes lowers the resolution in full screen visual effects for better performance.
You may change this behavior using this option.
Enable memory saving when minimized to tray:
If you enable this option, along with the "Minimize iTunes window to system tray" feature found in the Advanced tab of the Preferences dialog, the amount of memory iTunes is using will drop significantly when you minimize iTunes.
Foobar2000 passthrough:
Using this option will make iTunes play sound through the Foobar2000 engine.
You must have Foobar2000 0.8.3 or later for it to work.
This feature improves the sound quality, but it has several limitations:
1. Foobar2000 will not run simultaneously with iTunes when this option is enabled.
2. All the iTunes sound processing features will do nothing as long as this option is enabled.
3. After checking this option for the first time, you might hear an echo when listening to music. Restart iTunes to fix it.
You may include |No Foobar2000| in the Comments tag of a track to force it to play using the default engine.
This way it's possible to play tracks from the Music Store while Foobar2000 passthrough is enabled.
Don't stop playing when iTunes is being closed:
By default, closing iTunes stops the current track from playing.
With Foobar2000 passthrough enabled, you may change this behavior.
Note that only one track will continue playing - not the whole playlist.
EvilLyrics Integration:
If you have EvilLyrics installed, you will have a "Find Lyrics" option when you right click a track.
If you have liked this program, you may donate money to it's author by clicking the Donate button in the preferences dialog, or by navigating to the link below:
https://www.paypal.com/xclick/business=loca...rrency_code=USD
#2 User is offline   sky1983628 Icon
Posted 23 February 2006 - 05:22 PM
thx for this, localhost!
#3 User is offline   alchemist612 Icon
Posted 23 February 2006 - 05:25 PM
2.3 yes! thanks for the update!
#4 User is offline   drudragon Icon
Posted 23 February 2006 - 05:26 PM
Fantastic localhost, Thank-you so much :D,
#5 User is offline   ntchemist938 Icon
Posted 23 February 2006 - 05:32 PM
You always come through for us... much regards
#6 User is offline   Benji Icon
Posted 23 February 2006 - 05:35 PM
This is great, I might donate some money with my birthday coming up this Saturday.
#7 User is offline   Trent Pivot Icon
Posted 23 February 2006 - 05:42 PM
Thanks! I love the mini player it looks more mac-ish now! Only I have one problem :(
Posted Image
I have NO idea what is wrong :(
#8 User is offline   localhost Icon
Posted 23 February 2006 - 06:00 PM
Posted Image
Fixed.
Just redownload and reinstall.
#9 User is offline   siddharth Icon
Posted 23 February 2006 - 06:04 PM
Fantastic update my friend. Thank you very much.
#10 User is offline   dreadnaut Icon
Posted 23 February 2006 - 06:15 PM
Quote
uh, faster ? :confused:
#11 User is offline   idunno22 Icon
sweet update, thanks :)
#12 User is offline   Trent Pivot Icon
Posted 23 February 2006 - 06:22 PM
Thanks you da' man, now it is the shizznit.
#13 User is offline   sniper1747 Icon
Another awesome release :) continue your great work
#14 User is offline   Shekhar Icon
Posted 23 February 2006 - 06:26 PM
*WOWOWOWOW*
... you rock!!
#15 User is offline   kolouker Icon
Thank you so much! Keep up the great work :-)
#16 User is offline   localhost Icon
Posted 23 February 2006 - 06:54 PM
It seems strange, but I think it's because Windows makes more use of the graphics card when transparency is enabled.
#17 User is offline   lostspyder Icon
Posted 23 February 2006 - 07:05 PM
Yeah wow its awsome. Kudos to you localhost :D
My only gripe is that theres no way to preview the colorization afaik
#18 User is offline   iGo Icon
  • HAHAHAHA!!!!
  • Group: News Posters
Posted 23 February 2006 - 07:15 PM
You are one crazy son of a gun..... I thought 2.3 would be just a small update for full support to iTunes 6.0.3.... this is freaking as good as calling 2.5 !!! :D
Thanks a bunch mate !!
#19 User is offline   localhost Icon
Posted 23 February 2006 - 07:31 PM
Supporting iTunes 6.0.2/3 took me a few minutes, not a couple of months ;)
#20 User is offline   Dragon OTF Icon
Posted 23 February 2006 - 07:55 PM
localhost, that's great ! Thank you!
  • (18 Pages)
  • 1
  • 2
  • 3
  • Last »
1 User(s) are reading this topic
0 members, 1 guests, 0 anonymous users
