Aqua-Soft Forums: [Help] Transparent Clock - Aqua-Soft Forums
[Help] Transparent Clock Rate Topic: -----
#1 User is offline   corpse89 Icon
Posted 18 February 2006 - 09:46 PM
Hey I am new to Samurize and i wondered if anyone had the config for the transparent clock in this screenshot http://www.osx-e.com/gallery/showphoto.php.../sort/2/cat/506
#2 User is offline   aquaman99 Icon
Posted 19 February 2006 - 12:58 AM
newave said:
None of these elements are for release or share because permissions, so don't ask please... I'll have to say no
From the same screenshot on Deviantart
#3 User is offline   sketching Icon
Posted 19 February 2006 - 03:39 AM
Here's how you can make your own big ass clock:
1. Launch Instance Manager (sitting in your Samurize folder)
2. Click the "new instance icon" (2nd from the top-right corner)
3. Name it something like...BigAssClock
4. Choose your new instance from the list, then hit the "Edit Config File" icon (3rd from the bottom-right)
5. Once in the config editor, look over to the right where it says "Tools and Settings"
6. Click the "Add Meter" button to pull up a list of meters available to you. Choose "Add Time/Date"
7. Click on your newly added meter then go to the "Source" tab on the right side.
8. In the Format box, just put "hh:mm" (without quotes)
9. Go the "Display" tab
10. In the Text box, only have "%v" (without quotes)
11. While you are here, change the font, size, color to whatever you want it to be. The screenshot looks to have white text which is mostly transparent.
12. Save your new config (something like...BigAssClock.ini), then go back to the Instance Manager.
13. Click on "BigAssClock" (or whatever you named the instance) then click the 1st icon from the bottom-left.
14. Choose BigAssClock.ini from the drop-down list. Click Okay.
15. From the Instance Manager, click the 3rd icon from the bottom-left to launch your new instance.
16. Move the config to where you want it and make adjustments by editing the config file to your liking.
