Aqua-Soft Forums: [Help] Flyakite 3.0 logon/logoff screen - Aqua-Soft Forums
[Help] Flyakite 3.0 logon/logoff screen Rate Topic: -----
#1 User is offline   vitasg Icon
Posted 15 February 2006 - 01:46 AM
Is there a relatively simply way to alter the wallpaper image on the flyakite logon/logoff screens so that it matches my own wallpaper. For instance, I went to the Flyakite folder under the Windows folder on my harddrive, and in the subfolder logonui.exe (I think it's called), replaced the image labeled 100 with the wallpaper i'm currently using. However, upon re-start it didn't change, that is, the same deep blue aqua wallpaper that Flyakite has as the default was there. I'd like it to have Flyakites logon panel over the wallpaper that I am using.
Thanks.
#2 User is offline   tneo Icon
Posted 15 February 2006 - 06:02 AM
I'm not sure, but if you replaced the files in those folders, don't you need to update the regular windows files, with Flyakite's tool?
#3 User is offline   vitasg Icon
Posted 15 February 2006 - 06:07 AM
That's very possible. I don't know as I am a total novice at this. DO you what folders those are located in? Or does anyone reading this? Thnx.
#4 User is offline   tneo Icon
Posted 15 February 2006 - 06:16 AM
In the FlyakiteOSX start menu item there is a tool called "System File updater" just give that a try...
#5 User is offline   vitasg Icon
Posted 15 February 2006 - 06:20 AM
That only returns files to Flyakite-staus that have reverted to XP default. But thanks.
#6 User is offline   aquaman99 Icon
Posted 15 February 2006 - 10:25 PM
What tneo's talking about is that you need to force Flyakite to recognize your modded file instead of overriding it.
flyakite said:
With v3.0, to force update a file, the System Files Updater had to be called via the command line with the name of the file to update, like /shell32.dll.
#7 User is offline   vitasg Icon
Posted 15 February 2006 - 10:34 PM
Oh thanks. I'm not sure i still no what you mean though. Could you walk me through the steps?
By command line, do you mean the Run function?
#8 User is offline   aquaman99 Icon
Posted 15 February 2006 - 11:08 PM
Ok, i'll try. (although I might be wrong)
1.) Put logonui.exe into place.
2.) Click Run and type cmd.exe.
3.) Type in
 cd C:WindowsFlyakiteOSX
4.) Find that location in Explorer and figure out which file runs the System File Updater. Don't run it!!!!
5.) Type the name of the executable in the Commant Prompt with /logonui.exe. i.e. if the Updater is located at C:WindowsFlyakiteOSXsfupdate.exe type in
sfupdate.exe /logonui.exe
6.) Restart your computer and it should work. (I don't have a computer to test this on though)
#9 User is offline   vitasg Icon
Posted 15 February 2006 - 11:44 PM
Thanks for your reply.
Here's what I've done:
1. Opened C:WINDOWSFlyakiteOSXResourceslogonui.exe in Explorer;
2. Placed the desktop image I want to use in that folder. (It's .bmp file.) I renamed the wallpaper image that Flyakite uses from "100" to backup.100. I renamed my file "100";
3. Clicked on Run in the Start menu and typed cmd.exe;
4. Typed "C:WINDOWSFlyakiteOSXSystem Files Updater.exe" /logonui.exe and pressed enter
Then System Files Updater Wizard came up. I clicked OK to update, and it scanned some files and replied "Your System is already up to date. No files need updating at this time."
5. I restarted my computer, but the same Aqua wallpaper installed by Flyakite was there.
If you or anyone can tell me what I'm doing wrong, please do. Thanks all.
#10 Guest_SliWoady_*
  • Group: Guests
Posted 20 February 2006 - 04:45 AM
Just convert your wallpaper to bmp open up logonui with reshack and replace Bitmap 100
#11 User is offline   vitasg Icon
Posted 20 February 2006 - 05:02 AM
ResHack says "This is not a Win32 executable file" when I do that.
#12 Guest_SliWoady_*
  • Group: Guests
Posted 20 February 2006 - 05:16 AM
It didnt tell me that when i opened it, here's what i did step by step
1.Converted current wallpaper to BMP
2.Launched reshacker and opened logonui located at c:windows/system32/logonui.exe
3.Replaced bitmap 100 with wallpaper BMP and saved the logonui on my desktop
4.Used replacer (search google if you dont have it) and replaced the logonui in the system32 folder with the one on my desk
If you did what explained above it should work
#13 User is offline   vitasg Icon
Posted 20 February 2006 - 05:32 AM
oh ... the logonui.exe at the windows folder. I did it in the flyakite folder ...
Yes that works just fine. Thanks for your help and patience.
#14 Guest_SliWoady_*
  • Group: Guests
Posted 20 February 2006 - 05:38 AM
No problem.
#15 User is offline   vitasg Icon
Posted 22 February 2006 - 01:55 AM
Ok, sorry to return to this subject that I'm sure everyone figured was resolved, but the procedure outlined above works, but there's still a problem. There's a moment or two before the Flyakite Logon screen appears, where the original flyakite aqua bitmap image still comes on. it only lasts for a second or two. Does any know where THAT bitmap is stored so that i may reshack that as well? Thanks.
#16 User is offline   flyakite Icon
Posted 22 February 2006 - 09:46 AM
HKEY_USERS.DEFAULTControl PanelDesktop -> Wallpaper
Modify the value to be "C:WINDOWSFlyakiteOSXResourceslogonui.exe100.bmp" without the quotes. In the 3.5 update this is what the default value will be, so that if you make a change to the 100.bmp file, the bitmap image on the screen before the Logon Screen changes as well.
Also, the 3.5 update will make updating the files much, much, much easier. You will simply have to change the resource, and run a new tool selecting the file you want to update, and there you go.
