Aqua-Soft Forums: [help] Internet Explorer died after uninstalling Flyakite - Aqua-Soft Forums
[help] Internet Explorer died after uninstalling Flyakite Rate Topic: -----
#1 User is offline   mechaichezilla Icon
Posted 11 February 2006 - 02:11 PM
Hi, yesterday I removed Flyakite from my PC and it seems like it killed my IE. My mistake was, that I installed IE7.0 last week while Flyakite was running. Now it looks like Flyakite restored the IE DLLs from before it was installed (6 months ago or maybe a little earlier). So, what I have now is an IE7 that looks like an IE6 and doesn't work properly.
Here's the two error messages I get:
InternetGetSecurityInfoByURLW could not be located in the dynamic link library WININET.dll
and:
The indicated procedure could not be found
The last one is translated from the German message, so maybe the english message is a bit different.
Any Ideas how I can restore a functioning IE6? I guess the best way would be to remove the IE completely and install it again, but I have no idea how to do that.
Thanks
#2 User is offline   Desides Icon
Posted 11 February 2006 - 02:23 PM
Quote
Go to Add/Remove Programs, tick Show Updates at the top, and scroll down until you see IE7 listed.
#3 User is offline   sharknut Icon
Posted 11 February 2006 - 04:25 PM
apparently once you install IE 7, you can't go back to 6-i know because i had a problem with some software and when i called tech support and i told them that i had upgraded to 7 and tried to go back to 6 they said once you upgrade you can not roll back-try using a differnt iE shell like maxthon or something like that-
hope this helps
#4 User is offline   flyakite Icon
Posted 11 February 2006 - 07:05 PM
It's amazing what you can find with Google.... (IE6 Download: http://www.microsoft.com/downloads/details...&DisplayLang=en)
As for being able to uninstall IE7, you can. Like Desides said, in Add/Remove Programs check "Show Updates" at the top, and IE7 will be listed seperately.
