[help] no sound in itunes.
274
10-September 05
Posted 04 February 2006 - 11:30 PM
for some reason when i rebooted, itunes makes no sound.
it plays the song and everything, but there is no sound whatsoever.
i have no idea whats causing this.
help please?
795
11-December 05
Posted 04 February 2006 - 11:48 PM
Go to volume settings and uncheck mute.
Administrators
7,909
26-February 04
Posted 04 February 2006 - 11:51 PM
Do other applications work? Try Windows Media Player.
Stick a pair of headphones in the headphones jack and tell me if you get a lot of feedback/hissing from that...
274
10-September 05
....do you really think that i didnt check that?
but seriously, i tried WMplayer, ive watched videos with QT, everything's sound works except itunes
220
07-June 05
Posted 04 February 2006 - 11:53 PM
Are you using multi-plugin with the Foobar passthrough? If you are make sure that the volume setting is set above 0%.
274
10-September 05
Posted 04 February 2006 - 11:59 PM
no static/hissing.feedback with headphones or speakers.
i made a fresh itunes install - no dice.
this is so weird.
274
10-September 05
Posted 05 February 2006 - 12:17 AM
now WMP wont even play!!!
Administrators
7,909
26-February 04
Posted 05 February 2006 - 12:47 AM
Turn your computer off and give it a few minutes/hours to cool down. I know it's hard, but you can do it
That's always worked for me when I've had sound issues. Really weird, but there you go.
274
10-September 05
Posted 05 February 2006 - 01:30 AM
i sicked my father on it.
i can totally whomp him software wise, but he knows most about the hardware on this computer, he configured it when we first got it.
he just did some stuff with the sound drivers and fixed it.
but im still sort of curious why quicktime was still able the play audio.
3
28-November 08
Posted 28 November 2008 - 04:24 AM
OK I had some troubles with no sound in itunes as well.
I was looking through my volume controls, and found out that my pc had a different volume control for itunes. So weird...
Anyway, i have vista so you go to volume mixer and change the itunes volume control
hope i can help
Recruit
4
08-January 10
Posted 08 January 2010 - 01:54 AM
A few random suggestions which can be tried in case of no sound in iphones:
1. Try updating your drivers.
2. Check in the sound options that the correct sound output is selected. Sometimes there is another default option that might select when it's updated.
3. It may be an incompatibility with another piece of software. On my friend's Vaio, when he opens Fruity Loops he can't play sound out of iTunes, Youtube, or anything else.
Those are the only things I can suggest.
Recruit
1
30-April 10
Posted 30 April 2010 - 03:20 PM
hope i can help
Where is this "volume mixer" you speak of? I also have Vista.
Thank You
Sara Celti
