I think the widescreen will be a trend on the next yr. I hope the developer can concern on it more : )
[help] WidgetDock widescreen problem
#1
Posted 30 January 2006 - 10:10 AM
#3
Posted 30 January 2006 - 11:39 AM
the widget gets the resolution on startup and dont recognize if you change the resolution after that. you should reload the widget and it will fit your screen well again (position should be fine too then)
SioSae
btw my res is 1920x1200 ;-) so its a wiiidescreen
SioSae
Sign In »
Register Now!
Help
MultiQuote
